Why Doesn't the Coil Radius Affect the Induced EMF Calculation?
The problem involves a coil surrounding a solenoid, where the current in the solenoid varies with time. The task is to find the induced electromotive force (emf) in the coil as a function of time, using the relationship between magnetic flux and induced emf.
  • Participants discuss the relationship between the radius of the coil and the induced emf, questioning why the coil's radius seems irrelevant to the calculation. There are attempts to clarify the area used in flux calculations and the significance of the solenoid's magnetic field.
The discussion is ongoing, with participants exploring the implications of using the solenoid's area for flux calculations instead of the coil's area. Some guidance has been provided regarding the neglect of the magnetic field outside the solenoid in elementary problems.
Participants note that the distance between the coil and the solenoid may not affect the calculation of flux, raising questions about assumptions made in class regarding the relevance of the coil's radius.
Ithryndil
1. Homework Statement
A coil of 15 turns and radius 10cm surrounds a long solenoid of radius 2cm and 1x10^3 turns/m. The current in the solenoid changes as I = (5A)sin(120t). Find the induced emf in the 15-turn coil as a function of time.2. Homework Equations
emf = -Nd[flux]/dt
[tex]\Phi = \oint[B*dA][/tex]3. The Attempt at a Solution
Edit: I figured out what I was doing wrong. However, I am still puzzled on one aspect of this problem
When I figured out what I did wrong I came up with:
[tex]B = \munI[/tex]
[tex]Emf = \frac{d}{dt}(NBAcos\theta) = \frac{d}{dt}(NBA)[/tex] cos(theta) = 1 in this case
[tex]Therefore:<br /> Emf = NA\mun(I)[/tex] ...and we have I so it's a simple derivative from there
What I don't get is why the .1m radius doesn't really come into play. Unless I missed something or am not thinking here at all, it's not necessary for this problem, other than to tell us the coils are outside the solenoid.
Bump.
What area is the one you call A? The area of the solenoid i suppose.
When you calculate the flux through the coil you should use (in general) the area of the coil.
But... for a "long solenoid", the field on the outside of the solenoid is very weak and is usually neglected in elementary problems.
The field of the solenoid B=I*N/L (no area) is inside the solenoid - does not depend upon the area of the solenoid.
The A I am using is the area of the solenoid...at least the cross sectional area.
Also, let me correct a mistake in that last equation:
[tex] Therefore:<br /> Emf = NA(\mu)n\frac{d}{dt}(I)[/tex]
Then you should see why.
When you calculate the flux through something, you should use the area of the "something".
Here you use the area (cross-section) of the solenoid instead because the field outside the solenoid is neglected (and you don't have a formula for the field outside anyway, in elementary textbooks)
Ok, so it doesn't matter that the coil of 15 turns is .08 cm away from the solenoid, we only need the solenoid radius for the flux...hmm, I must have missed that in class.
