What is the Solution for x'(t) - x^2 = 1 given x(0) = 1?
  • Thread starter Thread starter brollysan
    Differential
The problem involves solving the differential equation x' - x^2 = 1 with the initial condition x(0) = 1. The subject area pertains to differential equations, specifically separable equations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the separation of variables in the context of the equation, with some expressing confusion about the absence of a second variable. There are attempts to manipulate the equation into a form suitable for integration, and questions arise regarding the correct interpretation of the integration results.
The discussion is ongoing, with various interpretations of the integration process being explored. Some participants offer guidance on how to approach the problem, while others question the validity of the derived expressions. There is no explicit consensus on the final form of the solution.
Participants note the challenge of applying standard methods from calculus to this problem, particularly regarding the roles of the variables involved. The initial condition is emphasized as a critical factor in determining the solution.
brollysan
x' - x^2 = 1, x(0) = 1
find x(t)
This was for an assignment due today, I kept trying but had to give up after 2 hours. I don't get the idea of seperable equations when there is just freaking x involved, what is it that I separate? And all the examples in my calculus made sure they did have a y and x, geez must be hard to separate those..
I just took a wild shot and arrived at: arctan x + 1
You separate x and t. x' must mean d(x(t))/dt. There certainly is an arctan in the problem. Take the examples in your calculus book and replace y and x by x and t.
ok so I end up with
dx/dt = 1+ x^2
and then I invert it and get dt/dx = 1/(1+x^2)
and then I get dt = 1/(1+x^2) dx
and take the integral and get x(t) = arctanx + C
and then 1 = arctan 0 + C
So I end up with x(t) = arctanx + 1 ?
I tried drawing it in python using eulers, and apparently what I have arrived at here is wrong
If you integrate dt=1/(1+x^2) dx you get t+C=arctan(x). You don't get an x on both sides. Integral dt=t+C. Not x+C.
Meaning that t+ C = arctan(x)
tan(t + C) = tan(arctan(x))
x(t) = tan(t + C) ?
So the solution is x(t) = tan(t + 0.25pi) ?
edit: It would have to be tan(t - 0.25pi) right?
Yes, x(t)=tan(t+pi/4). Just because the calculus book always uses y as the dependent variable and x as the independent variable doesn't mean they aren't allowed to throw a problem at you where t is the independent variable and x is the dependent. Just switch the letters around.
x(t) = tan(t + C) ?
No, tan(0-pi/4)=(-1). Your initial condition said x(0)=+1, not -1.
