Find the limit of the sequence as n tends to 1
  • Thread starter Thread starter sara_87
    Limit Sequence
The problem involves finding the limit of a sequence as n approaches 1, specifically the expression (3/(1-sqrt(x)) - (2/(1-cuberoot(x))). The discussion centers around the application of limits and L'Hôpital's rule in calculus.
  • Participants discuss the method of finding the limit by making a common denominator and expanding the expression. There are attempts to apply L'Hôpital's rule due to the indeterminate form encountered when substituting x=1. Questions arise regarding the correctness of the calculations and the necessity of applying L'Hôpital's rule multiple times.
The discussion is ongoing with participants providing feedback on each other's calculations. Some guidance has been offered regarding the application of L'Hôpital's rule, and there is an exploration of the implications of errors in the initial setup. Multiple interpretations of the limit are being considered.
There is a noted confusion regarding the application of L'Hôpital's rule and the resulting forms after substitution. Participants are also addressing potential errors in the algebraic manipulation of the expression.
sara_87
making a common denominator and expanding:
= lim [tex]\frac{1-3x^{1/3}+2x^{1/2}}{1-x^{1/3}-x^{1/2}+x^{1/6}}[/tex]
I then divided the whole thing by x^1/2 but didnt get anywhere.
Any help would be v much appreciated.
thank you
Simply substituting x=1 into this gives 0/0, so your limit is in one of the forms that qualify for l'hopital's rule...
ok,thanks so i used L'hospital's rule and got that the limit is 0; is that right?
Nope, you shouldn't be getting zero...there is actually an error in your first post: [tex]x^{1/3}x^{1/2}=x^{1/3+1/2}=x^{5/6} \neq x^{1/6}[/tex]
You will have to use L'hopistal's rule twice
you're right
but in that case, when i use l'hospitals rule once, i get 0/-0.5 = 0
so why must i use l'hospital's rule again?
You should be getting 0/0 after the first time (5/6-1/3-1/2=0 not -0.5)
Oh my, I am so stupid! i should have known that.
Yep, i see my mistake.
L'hospital's rule twice gives limit =1/2
right?
Yup! :smile:
Thanks.
  • · Replies 22 ·
