Angular momentum of a rigid body
The angular momentum of a rigid body system consisting of a 0.15 meter long, 0.15 kg thin rigid rod with a 0.22 kg mass on one end and a 0.080 kg mass on the other end, rotating at 1.7 rad/s, is calculated using the formula L = Iω. The moment of inertia (I) for point masses is determined by I = m1r1² + m2r2², where m1 and m2 are the masses and r1 and r2 are their respective distances from the center of rotation. The resulting angular momentum is 0.067 kg·m²/s.
  • Understanding of angular momentum and its formula L = Iω
  • Knowledge of moment of inertia for point masses
  • Familiarity with rotational motion concepts
  • Basic physics principles related to rigid body dynamics
  • Study the derivation of the moment of inertia for various shapes
  • Learn about the conservation of angular momentum in closed systems
  • Explore the effects of friction on angular momentum calculations
  • Investigate real-world applications of angular momentum in engineering
Physics students, mechanical engineers, and anyone interested in the dynamics of rotating systems will benefit from this discussion.
DH214
A 0.15 meter long, 0.15 kg thin rigid rod has a small 0.22 kg mass stuck on one of its ends and a small 0.080 kg mass stuck on the other end. The rod rotates at 1.7 rad/s through its physical center without friction. What is the magnitude of the angular momentum of the system taking the center of the rod as the origin? Treat the masses on the ends as point masses
What have you tried so far?
18K
  • · Replies 62 ·
14K
  • · Replies 22 ·
