Solving Rotational Kinematics: Moment of Inertia & Energy
The discussion revolves around a problem in rotational kinematics involving a uniform disk and a block on its rim. Participants are tasked with calculating the moment of inertia for both the block and the disk, as well as exploring the energy of the system and the acceleration of the block during rotation.
  • The original poster attempts to relate linear kinematics concepts to rotational kinematics but expresses confusion about the application. They question how to find the center of mass and apply Newton's second law in this context.
  • One participant provides a calculation for the moment of inertia of the block using a specific formula.
  • Another participant discusses the parallel axis theorem and expresses uncertainty about its application and setup.
  • Further clarification is sought regarding the calculation of the moment of inertia for the disk using the center of mass formula.
The discussion is active, with participants sharing their attempts and seeking clarification on various aspects of the problem. Some guidance has been offered regarding the moment of inertia calculations, but multiple interpretations and approaches are still being explored.
Participants are navigating the complexities of rotational dynamics, including the application of the parallel axis theorem and the relationship between linear and rotational quantities. There may be constraints related to the specific formulas and methods allowed in their homework context.
Awwnutz
http://img267.imageshack.us/img267/9499/diskwithblockpu2.gif
A uniform disk of mass Mdisk = 4.9 kg and radius R = 0.26 m has a small block of mass mblock = 2.6 kg on its rim. The disk rotates about an axis a distance d = 0.15 m from its center that intersects the disk along the radius on which the block is situated.
a) What is the moment of inertia of the block about the rotation axis?
b) What is the moment of inertia of the disk about the rotation axis?
c) When the system is rotating about the axis with an angular velocity of 4.2 rad/s, what is its energy?
d) If while the system is rotating with angular velocity 4.2 rad/s it has an angular acceleration of 8.9 rad/s2, what is the magnitude of the acceleration of the block?
Rotational kinematics
My attempt at the solution is just a bunch of chicken scratch. I had no problem with linear kinematics and my teacher keeps telling us that this is no different between that and rotational kinematics, but for some reason I'm just getting confused. I know: position = theta, velocity = omega, acceleration = alpha, mass = I (center of mass), Force = torque.
I'm not exactly sure how to find the center of mass and then use Newton's second law to find alpha and omega. I might be making this harder than it really is.
part a for I, i did:
Mblock*distance^2
2.6kg*(.26m-.15m)^2 = .03146kg*m^2, and this is correct.
for part b its is telling me to use the parallel axis theorem. I'm not too sure how to set it up. I know its the integral of a distance multiplied by the change in mass over a certain limit. But i don't know where to start.
The parallel axis theorem says:
I = Icom + Mass*Radius^2
So i have the mass of the disk, and the radius, how do i find the Icom?
Icom=1/2MR^2
  • · Replies 28 ·
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 40 ·
