Bernoulli's Equation on water hose
Bernoulli's Equation is applied to analyze water flow through a hose and nozzle system. The water flows at 0.67 m/s through a 3.0 cm diameter hose, transitioning to a 0.35 cm diameter nozzle, resulting in a speed of 49.22 m/s at the nozzle. The pressure at the nozzle is given as 1 atm, and the calculation for the pump pressure (P1) involves using the density of water (1000 kg/m³) and the velocities at both ends. The final pressure at the pump can be derived using the equation P1 = P2 + 1/2 D * V2² - 1/2 D * V1².
  • Understanding of Bernoulli's Equation
  • Knowledge of fluid dynamics principles
  • Familiarity with SI units and conversions
  • Basic algebra for solving equations
  • Learn how to apply Bernoulli's Equation in various fluid flow scenarios
  • Study the principles of laminar vs. turbulent flow
  • Research pressure conversion between SI units and atmospheres
  • Explore the implications of nozzle design on fluid velocity and pressure
Students in physics or engineering, fluid dynamics researchers, and professionals involved in hydraulic systems design will benefit from this discussion.
maniacp08
Water flows at 0.67 m/s through a 3.0 cm diameter hose that terminates in a 0.35 cm diameter nozzle. Assume laminar non-viscous steady-state flow.
(a) At what speed does the water pass through the nozzle?
49.22 m/s
(b) If the pump at one end of the hose and the nozzle at the other end are at the same height, and if the pressure at the nozzle is 1 atm, what is the pressure at the pump?
atm
I have found the answer for part A.
I have set up an equation for part B:
I have to find P1
P2 = 1 atm
v1 = .67 m/s
v2 = 49.22 m/s
let D = density of water = 1000kg/m^3
P1 + 1/2 D * V1^2 = P2 + 1/2 D * V2^2
P1 = P2 + 1/2 D * V2^2 - 1/2 D * V1^2
P1 = 1atm + 1/2(1000kg/m^3) * (2422.6084 m/s) - 1/2(1000kg/m^3) * (.4489m/s)
How do I convert this or get answer for P1 in terms of atm?
Most of your figures are in SI units. So I'd recommend working in SI, then converting at the end if you need the answer in terms of atm.
Your table of information / equation table should give you 1 atm in SI units. (If you don't have one, find the table of information / equation table you'll have in your exam, print it out, and refer to it constantly, so that you get used to where everything is!)
1 atm = 101.325 kPa
  • · Replies 16 ·
  • · Replies 30 ·
20K
