Subtracting integers with powers
The problem involves evaluating the expression 6667² - 3333² without the use of a calculator, which falls under the subject area of algebra, specifically dealing with powers and the difference of squares.
  • Exploratory, Conceptual clarification
  • The original poster expresses frustration over the problem, suggesting they believe there is a simple method to solve it. They mention checking their answer with a calculator and exploring the relationship between the integers involved. Some participants reference the concept of the difference of two squares as a potential approach.
Participants have provided reminders about relevant mathematical concepts, such as the difference of two squares, and have suggested that this may be a more efficient method for solving the problem. There is an acknowledgment of various approaches being discussed, but no explicit consensus has been reached.
The original poster indicates that the problem is worth only 2 marks, which may imply a focus on a straightforward solution. There is also a mention of previous classroom coverage of relevant concepts, suggesting some foundational knowledge may be assumed.
PhyStan7
Hey, sorry about this. Its really obvious, i think there's just some really simple way to do it. Its annoying me, my teacher couldn't do it either!
Evaluate 6667²-3333² (without a calculator)
I know there is just some really obvious way to do it. It was only worth 2 marks. Checking the answer on a calculator it was 33340000 and 6667-3333=3334 so i wasnt sure if that was how you did it, found the answer to the integers minus each other and add zeros. But i tried other examples and it didnt hold true.
Thanks
At some point in class, you should have covered what the difference of two squares is. Just to remind you, it looks something like this:
[tex]a^2-b^2=(a+b)*(a-b)[/tex]
I hope that helps.
You in general can also try to factorize the terms and calculate and simplify that way; but in the example you gave, knowing the difference of two squares is more efficient as in post #2.
Awesome, cheers guys!
  • · Replies 23 ·
14K
