Rotational mechanics and Angular Momentum- help needed to check over work
The discussion focuses on solving problems related to rotational mechanics and angular momentum, specifically addressing the calculation of speed and tension in a system involving a mass and a wheel. The user presents three problems, detailing their attempts and calculations, but expresses uncertainty about the correctness of their answers. Key equations used include torque, angular acceleration, and moment of inertia. The user seeks assistance in identifying errors in their calculations to ensure accurate results before submitting their homework.
  • Understanding of rotational mechanics concepts, including torque and moment of inertia.
  • Familiarity with angular acceleration and its relationship to linear acceleration.
  • Proficiency in using trigonometric functions for calculating components of forces.
  • Knowledge of converting between units, specifically degrees to radians.
  • Review the principles of torque and its calculation in rotational systems.
  • Study the relationship between angular and linear quantities in rotational motion.
  • Practice converting angles from degrees to radians for accurate calculations.
  • Explore common mistakes in applying rotational mechanics equations and how to avoid them.
Students studying physics, particularly those focusing on rotational dynamics and angular momentum, as well as educators looking for examples of common problem-solving errors in these topics.
ultrapowerpie
Please note, this is a series of problems, with a series of answers. I believe that I understand how to do the problems, but for some reason, my answer is wrong, and I can think of no reason why.
Problem 1: http://img355.imageshack.us/my.php?image=physics1jw9.png
i) I need to find the speed of the mass as it passes point B in m/s
ii) I need to find the Tension of the string (Which I am sure I can do, but without a correct answer for part i, I'm not going to attempt yet)
Problem 2: http://img186.imageshack.us/my.php?image=physics2pt6.png
Problem 3: http://img355.imageshack.us/my.php?image=physics3el2.png
(Note, the word that is cut off is longitudinal. I had to copy and paste parts of it into one picture, sorry it's a little shoddy <.<)
All the lovely rotational mechanics equations, and their linear counterparts
Problem 1
i) Ok, I did not take into account the spoke on the wheel whatsoever, since the mass of inertia was given to me, and the spokes of the wheel did not seem to have their own mass. Not sure if this would effect the problem.
T=I(angular a)
Angular acceleration = Torque/I
Torque= 46 KG * 9.8 m/s^2 * 3m = 1352.4
I= 3/4* 23 KG * 3^2 = 155.25
Ang A= 8.7111
a = (Ang A)*r
a= 8.711 * 3 = 26.133
Plugging this acceleration into the classic Xf= Xi + Vi +(at^2)*2 (assuming Vi and Xi are 0)
I get t=2.106
Then, using the Vf= Vi +at
I get Vf= 55.05
This answer is wrong though, not sure where I screwed up
Problem 2
This one seemed simple enough, just a basic torque= I * ang a
Ang a = T/I
I=(1/12)*(2.7)*(3^2)= 2.025
T= rxF
F= M*G= 9.8*2.7= 26.46
r= 3cos(43)=2.045
T= 54.137
Ang a= 26.734
It wants it in Radians/sec^2. Is it bad that I was using degrees for the cos?
Problem 3
I searched on google, and did come across this thread: https://www.physicsforums.com/showthread.php?t=17605
However, upon trying the forumulas given there, I still got it wrong. Using the formula ShawnD had at the end of his post, I got the wrong answer.
m= IW/rV
I= 2950
W=2 rev/min= .2094... rad/sec
r=2.9
V=755
I got M to be .282 kg
I then divided by .012 kg, and got that time = 21.87 s
This answer is also wrong, not sure what happened.
Thank you in advance for looking over this work.
Slight bump, sorry, but homework's due by Thursday Night. >.>
  • · Replies 17 ·
