Determining angle from initial velocity and distance
The discussion focuses on calculating the muzzle velocity and launch angle of a projectile fired from a gun that travels 122 km in 170 seconds. The horizontal velocity was determined to be 717.647 m/s, and the vertical component was calculated using the equation t = (-2Vy/-9.8), resulting in a final vector of 1099.502752 m/s. The angle was initially calculated using the equation D = (Vi²(sin(2theta)))/-9.8, yielding an angle of approximately 40.75 degrees, which was later questioned due to the existence of two possible angles for the sine function. The final approach involved using Vx and Vy to form a right triangle and applying trigonometric functions to accurately determine the angle.
  • Understanding of projectile motion equations
  • Familiarity with trigonometric functions and their applications
  • Knowledge of the Pythagorean theorem
  • Basic principles of kinematics, specifically relating to velocity and acceleration
  • Study the derivation and application of projectile motion equations
  • Learn how to solve for angles using inverse trigonometric functions
  • Explore the implications of air resistance on projectile trajectories
  • Investigate the use of simulation tools for visualizing projectile motion
Students studying physics, particularly those focusing on kinematics and projectile motion, as well as educators seeking to clarify concepts related to velocity and angle calculations in projectile dynamics.
Planefreak
A gun fires a round that goes 122 km in 170 seconds before impacting the ground. Ignore air resistance and the curvature of the earth. Find the muzzle velocity and angle.
Vx = Vi(cos(theta)) Yx = Vi(sin(theta)) t= (-2Vy/-9.8) and D=(Vi2(sin(2theta)))/-9.8
I found the correct muzzle velocity. Use distance 122*1000 then divide by time. This is horizontal velocity 717.647. Then use the third equation to find vertical. 170 = -2Vy/9.8.
Then use pythagorean to find final vector: 1099.502752
Now for the angle I used the fourth equation.
122000 = 1099.5027522(sin(2theta))/9.8
.9889931081 = sin(2theta)
40.74559192 degrees I guess this answer is wrong. I know the muzzle velocity is correct but according to the teacher it the angle is incorrect. Are my equations flawed or did I mess up?
The problem with the method you used is, there are two different angles between 0 and 90 where sine(2theta)=0.98899...
How using Vx and Vy to draw a right triangle, then use trig to get the angle?
I got it. I used the Vx velocity which was easy to find then found the height assuming that it is landing at the same height and used tangent to find the final velocity vector. Thank you.
