Calculate EMF: 3.25 ohm, 440 mH, 3.00 A, 3.60 A/s
  • Thread starter Thread starter Shackleford
The discussion focuses on calculating the electromotive force (emf) across a coil with a resistance of 3.25 ohms and an inductance of 440 mH, given a current of 3.00 A that is increasing at a rate of 3.60 A/s. The relevant formula used is emf = -L (dI/dt), where L is the inductance and dI/dt is the rate of change of current. By substituting the values into the equation, the emf can be determined, providing insights into the behavior of the coil under these conditions.
  • Understanding of electromagnetic induction principles
  • Familiarity with the formula emf = -L dI/dt
  • Basic knowledge of electrical resistance and inductance
  • Ability to perform calculations involving ohms and henries
  • Calculate emf for different values of inductance and resistance
  • Explore the effects of varying the rate of change of current on emf
  • Study the implications of inductance in AC circuits
  • Learn about the applications of inductors in electrical engineering
Electrical engineering students, physics enthusiasts, and professionals working with inductive components in circuits will benefit from this discussion.
Shackleford
A coil has a 3.25 ohm resistance and 440 mH inductance. If the current is 3.00 A and is increasing at a rate of 3.60 A/s, what is the potential decrease across the coil at this moment?
The only equation I know to use is
emf = - L dI/dt
Hi Shackleford,
emf = - L dI/dt
What would be the emf across a 3.25 ohm resistor in this situation?
alphysicist said:
Hi Shackleford,
Hello. Sorry. I took another quick stab at this problem and solved it correctly. I've kind of had a cold/mild flu lately.
