Two Normal Forces: Physics Explanation
  • Context: Undergrad
  • Thread starter Thread starter lax1113
    Forces Normal
The discussion centers on the mechanics of a box sliding down a folded ramp, creating two normal forces due to contact with two surfaces. The normal forces are not equal to half of the gravitational force (mg), as the box experiences different angles of contact, specifically 30 degrees and 60 degrees from vertical. Frictional forces are calculated separately for each ramp using the formula F_friction = μ * F_normal, where μ represents the coefficient of friction for each surface. The equilibrium of forces must be analyzed using the equations ΣF_y = 0 and ΣF_x = 0 to determine the exact values of the normal forces.
  • Understanding of normal force and its definition in physics.
  • Familiarity with the concepts of friction and coefficients of friction.
  • Knowledge of vector components and equilibrium equations in physics.
  • Basic grasp of inclined planes and their effects on forces acting on objects.
  • Study the principles of inclined planes and their impact on normal and frictional forces.
  • Learn how to resolve forces into components using trigonometric functions.
  • Explore the concept of static vs. kinetic friction and their coefficients.
  • Investigate the application of Newton's laws in multi-contact scenarios.
Students of physics, educators teaching mechanics, and anyone interested in understanding the dynamics of forces acting on objects in multi-contact scenarios.
lax1113
Hey guys,
So we haven't gotten to 3-d objects yet, but i was wondering, since Ff=Fn*mu, what would happen if an object was in a sort of like v, so that it had two normal forces.
Lets say it is a box, sliding down a 30degree ramp. The ramp is not just a ramp, but is folded so that it makes a 90 degree angle where the box rests. Because it is 90 degrees, the box is against the surface not only once, but twice, once on the left side of the box, once on the right. So, now that there are two normal forces, which have to be half of the mg i would guess, since the box is not accelerating in the y direction, would the friction also be half? Or is friction eqaul to the sum of Fnormal forces multiplied by Mu.
When i think about it just without applying any physics knowledge, it seems like a box being almost encased in a ramp, well at least on two sides, would slide less easily as a box only on one side. Then again, a lot of things i have learned in physics are contrary to common knowledge.
Yes, you would have two normal forces. No, they will not be each equal to 1/2 mg.
A "normal force" is simply a force of contact normal (or perpendicular) to the plane of contact. So if there are two points of contact, you will have two normal forces. In your example, the first normal force is oriented 30 degrees from vertical, becausae the box is on a 30 degree ramp. The second will be oriented 60 degrees from vertical, because the second ramp against which the box is jammed is a 60 degree ramp. If friction is involved, then there are two separate coefficients of friction, one for each ramp, and the forces of friction are Mu*Fnormal, one for each normal force, and each directed parallel to its ramp.
All four forces: two normal forces, and two frictional forces, have vertical components. You would have to set up [itex]\Sigma F_y = 0[/itex] and [itex]\Sigma F_x=0[/itex] and solve the equations to find what each normal force is.
  • · Replies 35 ·
  • · Replies 20 ·
  • · Replies 19 ·
