Finding the Ratio of Electron to Proton Speed in Beta Decay
The problem involves beta decay, where a neutron decays into a proton and an electron. The task is to find the ratio of the speeds of the electron and proton immediately after the decay, assuming the neutron is initially at rest.
  • Participants discuss the conservation of quantities during beta decay, particularly momentum and energy. Questions are raised about how to determine the speed of the electron post-decay and the relevance of conservation laws in this context.
Some participants have suggested considering conservation laws, particularly momentum, as a potential approach to the problem. There is an ongoing exploration of how these principles apply to finding the speed ratio, but no consensus has been reached yet.
Participants note the challenge of finding specific data regarding the speed of the electron after decay, indicating potential constraints in available information.
tater08
Beta decay is a radioactive decay in which a neutron in the nucleus of an atom breaks apart (decays) to form a proton and an electron. The electron is also known as a beta particle. The proton remains in the nucleus while the electron shoots out.
Assuming that the neutron is at rest inside the nucleus, find the ratio of the speed of the electron to the speed of the proton just after the decay.
I guess the only problem i have is where to find the speed of an electron after the decay. Does anybody know top hand or know where to search for the data?
Thanks!
Can you think of some quantity that is *conserved* during this process that might help you figure out what to do? (This is why we ask you to fill out part 2 of the template as well).
Well the charge is conserved so wouldn't that leave the E=mc^2 equation. Once you get the energy, you can plug that value into the KE=0.5 mv^2 in order to get the velocity?
I'll try to help you out a bit:
Basically, since the electron and proton are breaking apart and flying in different directions, you must think about what is conserved.
The immediate answer should be momentum. MeVe=MpVp
Note you're looking for the ratio of the speed of the electron to proton.
Good luck!
