Band Pass Filter Transfer Function Analysis
The discussion revolves around the analysis of a band pass filter's transfer function, focusing on deriving the values of capacitors based on given cutoff frequencies and resistor values. Participants explore the mathematical relationships involved in the filter's design and the challenges of solving simultaneous equations to find unknown capacitor values.
  • Homework-related
  • One participant presents a band pass filter configuration and seeks assistance in deriving capacitor values from the transfer function, given specific cutoff frequencies.
  • Another participant suggests that at the cutoff frequencies, the real and imaginary parts of the transfer function's denominator must be equal, allowing for the calculation of unknowns.
  • There is a discussion about using two equations derived from the cutoff frequencies to solve for the two unknown capacitors, C1 and C2.
  • Some participants express confusion about how to substitute values for omega when solving for C2 after finding C1, indicating uncertainty about the correct approach to simultaneous equations.
  • Clarifications are made regarding the use of different omega values for each equation to find the capacitor values, but participants still express uncertainty about how to proceed with the calculations.
Participants generally agree on the need to use simultaneous equations to solve for the capacitor values, but there is uncertainty and confusion regarding the substitution of omega values and the implications for finding C1 and C2.
Participants mention the assumption that a certain term can be considered zero at the center frequency, which may affect the derivation process. The discussion highlights the complexity of handling multiple unknowns and equations in the context of filter design.
pcrmx
A band Pass filter is given with the following configuration, R-Resistor, C-Capacitor:
https://www.physicsforums.com/attachment.php?attachmentid=16241&stc=1&d=1225999965
R1 = R2 = 10 kΩ
C1 and C2 are unknown
Cut off Frequencies are: F1 = 180 Hz, F2 = 5500 Hz
The transfer function derived is below:
https://www.physicsforums.com/attachment.php?attachmentid=16242&stc=1&d=1225999965
I have been informed that it can be assumed that ([C2 x R2] / C1) can effectively = 0, due to the fact that at the centre frequency the circuit effectively becomes a voltage divider, and at this point the gain would equal 1.
However I am unsure of how to derive the values of C from there, I have attempted to do make ([C2 x R2] / C1) = 0 and then put in values for omega, twice, once for each value of omega, and then tried using simultaneous equations to solve the c values, but with their being 2 values for omega I am getting stuck at a few points.
Any help would be greatly appreciated, thanks.
At the two cutoff frequencies the real and imaginary parts of the denominator of the TF must be equal.
You have two equations, so you can calculate two unknowns. Since you have 4 unknowns, you can assign arbitrary values to your capacitors and calculate the values of the resistors.
I don't follow, I already have the value of the resistors, I understand that I have to use two equations, with each omega value, but when you get to simultaneous equations I can re-arrange to get say C1, but then to get C2 what value of omega would I substitute into get that value. Previously you have used the two values to get the C1 value?
If you already have the values of the resistors, use the two equations to get C1 and C2.
In one equation you use [tex]\omega=2 \pi 180[/tex]. In the other [tex]\omega=2 \pi 5500[/tex].
Yes I get that part, but once you have a value of say C1, then in order to find C2 you must put C1 into the original equation. This original equation also has omega in it, for which I have two values. I am unsure of what value of omega to use, as I can get two values for C2 from this.
You work with the two equations simultaneously, each one with one value of the frequency. Two equations with two unknowns.
Thanks for your help, appreciate it.
  • · Replies 16 ·
