Is an ONB Complete in the Schwarz Space or Rigged Hilbert Space?
  • Context: Graduate
  • Thread starter Thread starter 0xDEADBEEF
    Complete
The discussion revolves around the completeness of an orthonormal basis (ONB) in the context of the Schwarz space and rigged Hilbert space, particularly in relation to eigenfunctions of Hamiltonians. Participants explore various approaches to demonstrate completeness, the implications of compact operators, and the nuances of eigenfunction behavior in different potential scenarios.
  • One participant questions the straightforwardness of demonstrating that an ONB is complete in the Schwarz space or rigged Hilbert space, raising specific queries about Hermitian operators and completeness.
  • Another participant mentions the result regarding the eigenfunctions of a compact, self-adjoint operator being dense in the range of the operator, indicating a potential connection to the completeness of ONBs.
  • Concerns are raised about the implications of modifying the potential in a harmonic oscillator problem, suggesting that the eigenfunctions may not span the same space and questioning the compactness of the new Hamiltonian.
  • There is a discussion about the nature of eigenvectors for operators like position and momentum, noting that they may not exist in the Hilbert space and that sums involving them may not be well-defined.
  • A participant introduces the idea that completeness is often assumed in textbooks, yet points to Sturm-Liouville equations as a potential independent method to establish the completeness of solutions, raising questions about the validity of such assumptions.
Participants express differing views on the completeness of ONBs, the implications of compactness, and the validity of assumptions made in textbooks. There is no consensus on these issues, and multiple competing perspectives remain throughout the discussion.
Participants highlight limitations in understanding the definitions of compact operators and the implications of modifying potential functions on the completeness of eigenfunctions. The discussion also touches on the mathematical rigor required when dealing with non-normalizable eigenvectors.
0xDEADBEEF
Is it possible to show that an ONB (orthonormal base is complete). I am quite irritated by the insertions of ones of the form [tex]\sum_{n} \left| \Psi_n \right\rangle \left\langle \Psi_n\right|[/tex] if the vectors are the eigenvectors of some Hamiltonian. So now the more precise questions:
1) Is there a straight forward approach to show that an ONB is complete in the Schwarz space, C2 or rigged Hilbert space.
2) If this is a property of Hermitian operators what are the restrictions? (the base formed by eigenfunctions of a finite potential well for example is obviously over complete)
3) If it is not straight forward: Let's say we have a well known ONB like the eigenfunctions of the harmonic oscillator. Then we take away the eigenfunction for one quantum number like n=5. How is it possible to show that this base is incomplete without the explicit use of that function?
I imagine if this is from a physics text/course, the result you are using is that the eigenfunctions of a compact, self-adjoint operator [tex]\mathcal{A}[/tex] are dense in [tex]R(\mathcal{A})[/tex].
That is already a useful result. Thank you.
But I am not sure, that I understand the notion of compact, or that I really have an understanding of [tex]R(\mathcal{A})[/tex] (I suppose it's the operator's range) There is a toy problem, where you take the harmonic oscillators potential, and set the potential to infinity for x<0. This way only every second wave function is allowed, because it has to be 0 at the origin. So now the eigenfunctions don't span the same space anymore as the usual harmonic oscillator's eigenfunctions. I suppose then, that the range of the new Hamiltonian is smaller, or is the operator it is not compact anymore?
If the first is the case, then inserting the "one" actually projects whatever vector to [tex]R(\mathcal{A})[/tex] which is not something a one should do.
You are correct - I mean the range of [tex]\mathcal{A}[/tex] by [tex]R(\mathcal{A})[/tex]. By [tex]\mathcal{A}:X\rightarrow Y[/tex] being compact, I mean that the image under [tex]\mathcal}A[/tex] of any bounded subset of [tex]X[/tex] has compact closure in [tex]Y[/tex], or equivalently for any bounded sequence [tex]\{x_n\}[/tex] in [tex]X[/tex], the sequence [tex]\{\mathcal{A} x_n\}[/tex] in [tex]Y[/tex] contains a convergent subsequence.
0xDEADBEEF said:
So now the eigenfunctions don't span the same space anymore as the usual harmonic oscillator's eigenfunctions. I suppose then, that the range of the new Hamiltonian is smaller...
the new hamiltonian is only well defined on the space of square integrable functions psi(x) satisfying psi(x)=0 for x<= 0 -- otherwise you would be multiplying a non-zero number by infinite potential. Its range is dense in this space, and so is the space generated by its eigenvalues (so you have an onb).
0xDEADBEEF said:
...or is the operator not compact anymore?
no, and it wasn't compact in the first place. It's not even bounded.
for an operator such as position or momentum [itex]p=-i\hbar\partial/\partial x[/itex], the eigenvectors are non-normalizable or delta functions so don't exist in the hilbert space at all. So the sum is just 0. Even generalizing to distributions, they form a continuum and a discrete sum wouldn't make sense. One way to make the expression well defined mathematically is to use the spectral decomposition which replaces the sum as an integral w.r.t. a spectral measure.
I learned about that. I think we used projector valued measures, or whatever the English name is. But it is good to know that we mostly don't even know what we are doing, and that we have to understand the domain and range of the operator that we are dealing with really well.
Here's something one can think about...
Most of the books assume completeness (JJ Sakurai, David J Griffiths, R Shankar)
However, after assuming this completeness, when we have introduced the notion of a wavefunction, we can set up the differential equation for the eigenfunctions of the operator (whose eigen-set we said formed a complete ONB). These differential equations turn out to be Sturm-Liovelle equations. And the proof of the completeness of solutions to the Sturm Liovelle differential equations is well known to Mathematicians. (Search on wiki/ google/ wolfram)
Of course, one might say, but hadn't we assumed the completeness? Then we're bound to get the same!
To that, I say, there perhaps was an independent way of getting to the eigen-functions... Which would have then proved the completeness of the ONB!
  • · Replies 0 ·
11K
