Billiard ball collision with change in direction
The discussion centers on a physics problem involving the inelastic collision of billiard balls. A 0.210 kg billiard ball traveling at 6.25 m/s collides with a stationary ball, resulting in the second ball moving at an angle of 25 degrees with a speed of 3.0 m/s. The impulse received by each ball and the final velocity of the first ball are calculated using momentum conservation principles. The final speed of the first ball is determined by analyzing the momentum components in both the x and y directions.
  • Understanding of momentum conservation principles
  • Knowledge of impulse and its calculation
  • Ability to resolve vectors into components
  • Familiarity with inelastic collisions
  • Study the concept of impulse and its relation to momentum
  • Learn how to resolve vectors into x and y components
  • Explore inelastic collision problems in physics
  • Practice calculating final velocities after collisions using conservation laws
Students studying physics, particularly those focusing on mechanics and collision problems, as well as educators looking for examples of inelastic collisions and impulse calculations.
mariac
A billiard ball with mass 0.210 kg has a speed of 5.2 m/s and collides completely inelastically with another ball of the same size and mass.
A. Find the final speed of the two balls.
The answer I got was 2.6 m/s. The next part is trickier.
B. Another billiard ball traveling at 6.25 m/s collides with a second stationary ball of equal size and shape causing the second ball to move at an angle of 25 degrees with respect to the horizontal at a speed of 3.0 m/s.
What impulse (magnitude and direction) did the each ball receive? What is the final velocity (magnitude and direction ) of the first ball?
Conceptually, I don't understand why the second ball would move at an angle. Would that mean that the first ball hits the second ball off-center? I know that the total momentum must remain the same, and p=6.25m/s x 0.210kg = 1.31kg m/s. Would this be the magnitude of the impulse received by the second ball? Or would the impulse be only half of this since the first ball receives an equal impulse? If the first ball hit the second slightly off center, this would change the direction of the impulse. I presume the first ball would turn 25 degrees below horizontal after the collision. Would the first ball proceed at a velocity of 3.25 m/s, or would the change in direction somehow affect the velocity?
I'm really confused. Can you help?
I don't have much experience w/ impulse, but your guesses seem correct. It would be an off-center hit to cause this. To find out the direction/magnitude of the first ball, break it into x-y components. In both an x and y sense separately, Start momenta added together should equal final momenta added together. You can find out the starting momenta of both balls, and the final momentum of the second ball; which will allow you to solve for the final momentum of the second ball. Done in x and y you will have components, then you can switch it back to polar (direction, magnitude).
  • · Replies 19 ·
  • · Replies 38 ·
