Torque and Acceleration question
The discussion revolves around a problem involving torque and angular acceleration of a solid wheel that comes to a stop after a specified number of rotations. The participants are exploring the relationships between angular acceleration, tangential acceleration, net torque, and energy required to stop the wheel.
  • Mixed
  • Participants are attempting to calculate angular acceleration, tangential acceleration, net torque, and energy required to stop the wheel. There is a focus on verifying calculations and addressing potential errors in the initial attempts.
Some participants are questioning the accuracy of the initial calculations, particularly regarding the angular acceleration. There is a suggestion to clarify the calculations for part (a) and to consider the relationship between work done by torque and energy required to stop the wheel. The discussion is ongoing with various interpretations being explored.
There is a noted typo in the original post regarding the initial angular velocity, which has led to confusion in subsequent calculations. Participants are also discussing the implications of this error on the overall problem-solving process.
veronicak5678
A solid wheel (I = 1/2 MR^2) initially rotating at 5 rad/s comes to a stop after 8 rotations.
a) Angular acceleration?
b) Tangential accelration at the rim?
c) If the mass is 2 kg and the radius is 1.5 m, find the net torque.
d) Using values form c, how much energy was required to bring the wheel to a stop?
a) -24.9 rad/s^2
b) -37.4 m/s^2
c) -56 Nm
d) I am not sure how to find the energy used.
part(a) is incorrect and that error propagates through to (b) and (c)...perhaps you should show me how you got part (a)...
For part a I used (w for omega for tangential velocity, a for alpha for angular acceleration )
w final ^2 - w initial^2 = 2a delta angle
(0 - (50 rad /s)^2 ) / (2 (50.3rad))
= -24.9 rad /s^2
Your original post said the w_initial=5rad/s not 50...if it is 50 then your original answer is correct.
As for the energy required to stop the wheel; it should be the same as the 'work done by the torque' over an angular distance of 8*2pi...does that help?
Sorry for the typo!
So the energy used will be 8* 2pi (-56.0Nm) ?
  • · Replies 17 ·
  • · Replies 30 ·
