Noob questions about electricity and magnetism
The discussion revolves around the concept of voltage in electricity and magnetism, exploring its definitions, applications in circuits, and analogies to other systems. Participants express confusion about the transition from electrostatic voltage to its role in circuits, as well as the implications of voltage differences in practical scenarios.
  • Homework-related
  • One participant compares voltage to potential energy in a river system, questioning the validity of this analogy and seeking clarification on what voltage represents in this context.
  • Another participant asserts that voltage in a circuit is the same as in electrostatics, explaining how a battery maintains a voltage difference and how electric fields behave in circuits.
  • A participant seeks clarification on the definition of voltage between battery terminals, pondering whether it relates to charge differences and the effect of distance on voltage.
  • One participant defines voltage as the work required to move a charge between two points, equating one volt to one joule per coulomb, while another expresses confusion about the implications of this definition at points with charges.
  • Another participant likens voltage to pressure in a fluid system, suggesting that it represents potential energy and drives current when a path is available, while critiquing the river analogy for its reliance on gravity.
  • A participant questions whether current remains constant throughout a circuit and how energy is stored in the flow of electrons, as well as what factors determine a battery's voltage.
  • One participant reiterates the definition of voltage and raises a concern about the potential being infinite at a point of charge, prompting discussion about how potential is calculated in systems with multiple charges.
Participants express various interpretations of voltage and its applications, indicating that multiple competing views remain. There is no consensus on the best analogy for understanding voltage or the implications of its definitions in practical scenarios.
Some participants express confusion regarding the relationship between voltage, current, and resistance in circuits, as well as the implications of voltage definitions when applied to point charges. There are unresolved questions about the nature of current flow and energy storage in circuits.
Bigman
I'm a little confused about "voltage". We learned that voltage is somewhat similar to electric field: a way to refer to the potential energy of a charge A when put near charge B without actually knowing the charge of charge A. That made sense to me, but then suddenly in class (this is college physics by the way) we're referring to the voltage in a battery as a source of current... and i guess i didn't really get the transition from the voltage of a point in relation to a point charge, and voltage as some abstract value of a circuit that's equal to the current times the resistance. I mean i can do the math and solve circuit problems, the whole E=IR thing is simple enough to use, but i don't get how "voltage" applies to the situation. I kind of see circuits being similar to a river with a mill in it- as the water flows by the mill some of it's kinetic energy is transferred to the wheel. While the current of the water is the same before and after the water interacts with the wheel, the velocity(and energy) of the water changes. Is this a good way to think of it or is this a horrible comparison? And if it's a sound comparison, what would the "voltage" be, the difference in gravitational potential energy between the source and mouth of the river?
The voltage in a circuit is exactly the same kind of voltage as in electrostatics.
A battery is a device which maintains a voltage difference between its two terminals. If you let a battery sit in empty space, then there will be an electric field around the battery that looks like a dipole field.
When you connect a wire to the battery, the electric field tends to concentrate along the direction of the wire. This is because the wire has a very high dielectric constant (a perfect conductor is the limit as you take the dielectric constant to infinity). Thus, when you complete a circuit with a wire, most of the electric field goes along the wire, and pushes charges around the circuit.
Compare to taking a magnet and putting an iron loop between the two poles: because the iron has a very high permeability, the magnetic field lines tend to concentrate inside the iron loop.
Thanks for the response :) What do you mean by the voltage between the two terminals? is it the difference in charge (which should be twice the charge of either terminal, right?) divided by the distance between them? and does this mean that if you took the terminals of a battery and pulled them apart you would change the voltage?
The "voltage between two points" is by definition the work (energy) it takes to move a charge between those two points, divided by the amount of charge. One volt equals one joule per coulomb.
I hope this doesn't sound too simplistic, but voltage in an electrical system can be thought of like pressure in a fluidpower system. It is the potential energy of electricity. Like pressure (the potential energy in a fluid), voltage exists because of a difference in potential between two parts in the system. When a path or outlet for this energy is available, it is this potential energy which drives the current (whether fluid or electrical).
I think your analogy of a river turning a waterwheel only fails in that a river uses gravity for its potential energy. So, after passing by the wheel, the water can begin accelerating again, as gravity acts like a constant input of new energy. Replace your fluid source with a pressure pump feeding enclosed tubes or hoses, and you're there.
I've heard this definition before and i get it, but when applied to points with charges it confuses me because isn't the voltage AT a point of charge infinite?
I've been going through my (crappy) textbook and i still don't really "get" what's actually happening in a circuit. The whole voltage thing is beginning to make a little more sense to me, though now i have a few more questions that the book doesn't really explain: is the current constant throughout a circuit, or does it change after the electrons run through resistance? If current is constant, then how is energy stored in the flow of electrons? Also, what determines the voltage of a battery? I would imagine that one of the major factors would be the rate at which the chemicals inside the battery can react and create ions, is that it or are there other larger factors at work? TIA
When figuring the potential at the location of a point charge, you don't include that charge itself. The potential is calculated from all the other charges in the system.
  • · Replies 21 ·
  • · Replies 58 ·
