| Thread Closed |
Diffraction of sound waves |
Share Thread | Thread Tools |
| Nov8-08, 02:14 AM | #1 |
Diffraction occurs for all types of waves, including sound waves. High-frequency sound from a distant source with wavelength 9.20 cm passes through a narrow slit 11.5 cm wide. A microphone is placed 35.0 cm directly in front of the center of the slit. The microphone is then moved in a direction perpendicular to the line from the center of the slit to point O, the center of the diffraction pattern. At what minimal distance from O will the intensity detected by the microphone be zero? 2. Relevant equations [tex]sin \theta = \frac{m\lambda}{a}[/tex] [tex]tan \theta = \frac{y}{L}[/tex] [tex]\lambda = 9.20 cm, a = 11.5 cm, L = 35.0 cm, m = 1 [/tex] 3. The attempt at a solution [tex] tan \theta = sin \theta [/tex] [tex] \frac{y}{L} = \frac{m\lambda}{a}[/tex] [tex] y = \frac{m\lambda L} {a} [/tex] [tex] y = \frac{1 \times 9.20 cm \times 35.0 cm}{11.5 cm}[/tex] y = 28 cm However, this is not the correct answer. The correct answer is given as y = 46.7 cm. I suspect that my solution didn't work because the angles are not small enough so that the sine and tangent functions can not be set equal to each other. How do you get the correct answer? |
| Nov10-08, 01:28 PM | #2 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Diffraction of sound waves
| Can light enegry or waves affects sound waves? | General Physics | 7 | ||
| why will ultrasonic waves not interfere with other sound waves in water? | Introductory Physics Homework | 1 | ||
| Sound Intensity and Sound Waves | Introductory Physics Homework | 5 | ||
| Diffraction of Waves | General Physics | 6 | ||
| DIffraction and Waves | General Physics | 2 | ||
