Is this result by coincidence or by implication?
The discussion revolves around a geometric puzzle involving Pythagorean triples, specifically exploring the relationships between different sets of natural numbers that satisfy certain conditions. Participants examine whether the emergence of additional Pythagorean triples from given conditions is coincidental or indicative of deeper mathematical implications.
  • One participant presents a problem involving finding natural numbers a, b, and c that form a Pythagorean triple and also lead to another Pythagorean triple when manipulated.
  • Another participant outlines a proof involving the expansion of equations and substitution to explore the relationships between the triples.
  • Some participants discuss the implications of the conditions given in the problem, questioning whether the additional Pythagorean triple is a coincidence or has a mathematical basis.
  • There are mentions of specific mathematical properties, such as the conditions under which certain triples can be derived and the implications of evenness in Pythagorean triples.
  • Participants share their progress on proofs and express gratitude for clarifications on complex steps in the reasoning process.
Participants express varying degrees of understanding and approaches to the problem, with some agreeing on certain steps in the proof while others question the implications of the findings. The discussion remains unresolved regarding whether the additional Pythagorean triple is a coincidence or has a deeper mathematical significance.
Participants rely on specific assumptions about the properties of Pythagorean triples and the conditions of the problem, which may not be universally applicable. The discussion includes complex mathematical reasoning that is not fully resolved.
uart
The other day someone gave me a puzzle. It was a geometry type puzzle but I was a able to reduce it to a set of pythagorean triads. Essentually the problem turned out to be equilvalent to the following.
Find natural numbers a, b and c (each less than 42) such that {a, b, c} forms a Pythagorean traid and {(c-a), b} are also the first two elements of a second Pythagorean triad.
That is, a^2 + b^2 = c^2 and (c-a)^2 + b^2 = n^2 for some natural number n.
Since it was given that the problem had a solution it was a pretty easy matter of testing a few PT's to find the one that worked and I quickly found {a, b, c} = {7, 24, 25}.
Later it caught my attention that, {(c+a),b . }, also formed a Pythagorean triad, though this was not a requirement of the original problem. At first I suspected that this might be an implication of the other conditions but I was unable to deduce any such implication. So I thought I'd post it here and see if anybody else knew of any reason for that last PT other than just coincidence.
Mathematics news on Phys.org
BTW. Here is the original puzzle if anyone is interested.
I cut a rectangle from a piece of A3 paper (approx 42 by 30 cm). Both the length and height of the rectangle are a whole number of cm and when this rectangle is folded such that the diagonally opposite corners align then it forms a pentagon in which all five sides are also a whole number of centimeters. Find the size of rectangle that I cut.
The answer is (c+a) by b, for the a, b and c given previously.
I have a proof but, since it's rather long, I'll just outline the path and let you complete it. (If somebody sees a simpler way, please post it!)
Suppose you are given that {a,b,c} and {c-a,b,d} are Pythagorean triples. From the second, expanding (c-a)^2 + b^2 = d^2 and substituting a^2 + b^2 by c^2, you will get at 2c(c-a) = d^2.
Now prove the following lemma: "if {x,y,z} is a Pythagorean triple and z is even, then x and y must also be even".
Let {e,f,g} be the Pythagorean triple {(c-a)/2, b/2, d/2}, and arrive to ce = g^2.
Repeat everything for the triple (yet to be proven Pythagorean) {c+a,b,q}: either it is not Pythagorean, or ch = q^2, where h is the integer (c+a)/2.
Now prove that, if ce is a square and ch is also a square, then e = h . k^2 for some integer k. (Note that, in your example, c itself is a square, but this is not necessary for this proof.) Substitute into ce = g^2 in order to prove ch = q^2.
Good work dodo you've got it. :)
Yes I was wondering if that was part of the "co-incidence" or not.
ok that was the bit I was missing but I've got it now, many thanks.
I think this is about as simple a proof as I can make of this.
Given
[tex]a^2 + b^2 = c^2[/tex]
and
[tex](c-a)^2 + b^2 = n^2[/tex]
Expand the second equation and substitute for b^2 from the first to get,
[tex]2 c (c-a) = n^2[/tex]
Consider the triple, {(c+a), b, [itex]\sqrt{(c+a)^2 + b^2}[/itex]}
Clearly this is a Pythagorean triple if [itex](c+a)^2+b^2[/itex] is a square number.
As before expand and substitute for b^2 to get,
[tex](c+a)^2 + b^2 = 2 c (c+a)[/tex]
[tex]\,\,\,\,\,\,\, = \frac{2 c (c^2 - a^2)}{c - a}\,\,\,\,\,\,\,\,[/tex] : difference of two squares.
[tex]\,\,\,\,\,\,\, = \frac{2 c b^2}{c - a}\,\,\,\,\,\,\,\,[/tex] : since b^2 = c^2 - a^2
[tex]\,\,\,\,\,\,\, = \frac{4 c^2 b^2}{n^2}\,\,\,\,\,\,\,\,[/tex] : substituting for (c-a) from the 3rd equation.
So [itex]\sqrt{(c+a)^2 + b^2 }[/itex] is rational and therefore integer (by the rational root theorem).
[tex]\frac{4 c^2 b^2}{n^2}[/tex] is a square 'by eye'... it's the square of 2bc/n. And it can be verified (with some more lengthy expanding) that { (c+a), b, 2bc/n }, with [tex]n = \sqrt { (c-a)^2 + b^2 }[/tex], is a Pythagorean triple.
Anyway, that's certainly shorter than what I did!
  • · Replies 22 ·
  • · Replies 19 ·
  • · Replies 21 ·
