Proving an Inequality: Using the Mean Value Theorem
  • Thread starter Thread starter springo
    Inequality
The original poster seeks to prove an inequality for the variable x within the range of 0 to positive infinity, suggesting a connection to the Mean Value Theorem.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the implications of restricting x to positive values and explore the relationship between the inequality and the Mean Value Theorem. There are attempts to derive bounds and clarify the roles of specific functions and their derivatives.
The discussion is ongoing, with participants providing hints and exploring various interpretations of the Mean Value Theorem in relation to the problem. Some have offered guidance on the function and its properties, while others are questioning assumptions and clarifying details.
Participants note that the inequality holds for a specific range of x-values and are considering the implications of this restriction on their reasoning. There is also mention of needing to understand certain logarithmic relationships to progress further.
springo
I need to prove an inequality for 0 < x < +∞.
I guess it must be something with the mean value theorem, but I can't find what it is.
Thanks for your help.
Edit: Added range for x.
  • eq.latex?1-\frac{x}{2}%20\leq%20Ln(3+cos%20x)%20\leq%20\frac{3}{2}+\frac{x}{2}.gif
This inequality is only true for a select range of x-values, so what range are you supposed to prove this for?
Sorry forgot to say: 0 < x < +∞
I don't see where restricting x to the positive reals does anything for you.
2 <= 3 + cos(x) <= 4, for all real x, so ln(3 + cos(x)) is defined for all real x, as well.
Taking logs, the inequality above becomes
ln(2) <= ln(3 + cos(x)) <= ln(4) = 2ln(2)
I don't see how the lower and upper bounds of the original inequality figure in, though.
Hint: Let [itex]f(x)=\ln (3+ \cos x)[/itex]...what does the mean value theorem have to say about [itex]f(x)-f(0)[/itex]?
With:
Right?But still, I can't think of anything but making that:
And then replacing, but still nothing.
Perhaps we should go over the mean value theorem first...it says that for some [itex]c \in [a,b][/itex]
, the following will hold true:
[tex]\frac{f(b)-f(a)}{b-a}=f'(c) \Rightarrow f(b)-f(a)=(b-a)f'(c)[/tex]
So looking at [itex]f(x)-f(0)[/itex] means [itex]a=0[/itex] and [itex]b=x[/itex] in the above relation right?...what does that give you?
I thought [tex]b = 3+cos x[/tex] and [tex]a = 3+cos 0 = 4[/tex] :rolleyes:
So for: [tex]0 \leq l \leq x[/tex] we have:
[tex]ln(3+cos x) - ln(4) = \frac{x}{l}[/tex]
Is that right so far?
What happened to [itex]f'(l)[/itex]?
OK, I forgot that it's not [tex]ln(l)[/tex] but rather [tex]ln(3+\cos l)[/tex]
So the derivative would be:
[tex]-\frac{\sin l}{3+\cos l}[/tex]
So finally:
[tex]\ln(3+\cos x)-\ln 4 = \frac{-x\sin l}{3+\cos l}[/tex]
good, and what are the minimum and maximum values of [tex]\frac{-\sin l}{3+\cos l}[/tex] for any real [itex]l[/itex]?
The only way I can think of for doing that is:
[tex]\frac{1}{2}\geq\frac{1}{3+\cos l}\geq\frac{1}{4}[/tex]
And:
[tex]1\geq-\sin l\geq-1[/tex]
Therefore:
[tex]\frac{1}{2}\geq\frac{-\sin l}{3+\cos l}\geq-\frac{1}{4}[/tex]
Close, the actual relationship is:
[tex] \frac{1}{2}\geq\frac{-\sin l}{3+\cos l}\geq-\frac{1}{2}[/tex]
(since -1/4 is actually greater than -1/2 not less than)
Given this, and the fact that you are restricted to positive x-values, what are the restrictions on [tex]\frac{-x\sin l}{3+\cos l}[/tex] ?
And hence what are the maximum and minimum values of [itex]f(x)-f(0)[/itex]?
OK, I think I got it now, but am I supposed to know that [tex]1\leq\ln4\leq\frac{3}{2}[/tex] in order to answer or is there any way around it?
I think that's all there is to it.
OK, thanks a lot!
