Concentrations of Pb2+ and Cl2 at equilibrium
  • Thread starter Thread starter magma_saber
    Equilibrium
The discussion focuses on calculating the equilibrium concentrations of Pb2+ and Cl- ions after mixing 50.0 mL of 0.36 M Pb(NO3)2 with 50.0 mL of 1.7 M KCl. The solubility product constant (Ksp) for PbCl2 is given as 1.6 x 10-5. Participants clarify that the Ksp expression should be based on the concentrations of the ions, not the original compounds, and emphasize the importance of identifying the limiting reagent to determine the remaining concentrations at equilibrium.
  • Understanding of Ksp and solubility equilibria
  • Knowledge of stoichiometry and limiting reagents
  • Familiarity with molarity calculations
  • Basic principles of chemical equilibrium
  • Study the Ksp calculations for ionic compounds
  • Learn about limiting reagents in chemical reactions
  • Explore equilibrium concepts in aqueous solutions
  • Review molarity and dilution calculations
Chemistry students, educators, and anyone involved in chemical analysis or laboratory work related to solubility and equilibrium calculations.
magma_saber
A solution is prepared by mixing 50.0 mL of 0.36 M Pb(NO3)2 with 50.0 mL of 1.7 M KCl. Calculate the concentrations of Pb2+ and Cl2 at equilibrium. Ksp for PbCl2(s) is 1.6 x 10-5.
I think its Ksp = [Pb(NO3)2][KCl]2
Pb(NO3)2 = 0.018 mol
KCl = 0.085 mol
Is this right? what do i solve for?
Your Ksp is wrong. It should be made of ions concentrations.
Otherwise it is limiting reagent question. Once everything precipitates out, you will be left with the excess of one of the ions involved. Use this concentration to calculate concentration of the other using (correct) Ksp formula.
  • · Replies 19 ·
10K
