| Thread Closed |
cannonball velocity problem |
Share Thread | Thread Tools |
| Nov10-08, 05:32 PM | #1 |
A 30 kg cannonball strikes a 150 kg stationary wooden block and embeds itself in the block. The block and cannonball move together at 4 m/s. What was the original velocity of the cannonball? 2. Relevant equations m1v1=m2v2 3. The attempt at a solution using the equation i gave i got: 30v=150(4) v=20 the answer my teacher my teacher gave me was 24 m/s. and i was thinking if you add the '4 m/s' to the velocity i just found it would be '24 m/s'. but i dont know if that was right. i was thinking it might be right because they both moved together after the ball hit the wood for 4 m/s. so is that right? or am i supposed to do something else? thank you! sweedeljoseph |
| Nov10-08, 05:34 PM | #2 |
The mass after the collision would be the masses of both objects added together since they are now considered to be one object moving at the same velocity.
m1V1 + m2V2 (equals 0) = v'(m1 + m2) Solve for V1 before |
| Nov10-08, 05:35 PM | #3 |
so i was right? you add the '4 m/s' to the velocity that i found?
| Thread Closed |
| Tags |
| cannonball, velocity |
| Thread Tools | |
Similar Threads for: cannonball velocity problem
| Kinematics. cannonball was dropped- how far from the wall does it hit ground? | Introductory Physics Homework | 1 | ||
| Ripple deSitter universe---Randono cannonball analog | Cosmology | 2 | ||
| Velocity Problem | Introductory Physics Homework | 6 | ||
| Does this look right? Cannonball question.. | Calculus | 4 | ||
| Need help w/ velocity problem | Introductory Physics Homework | 8 | ||
