What is the difference between strain rate and velocity gradient?
The discussion clarifies that for a Newtonian fluid, strain rate and velocity gradient are equivalent and directly proportional to shear stress, governed by the second viscosity coefficient. The equation for normal shear stress in the x-direction is expressed as τxx = λ (∇·V) + 2μ(∂u/∂x), highlighting the velocity gradient's role. It is noted that λ is challenging to measure, leading to the application of Stoke's Hypothesis, which simplifies λ to -2/3μ for practical calculations.
  • Understanding of Newtonian fluid dynamics
  • Familiarity with shear stress concepts
  • Knowledge of viscosity coefficients
  • Basic grasp of vector calculus
  • Study the implications of Stoke's Hypothesis in fluid dynamics
  • Explore the measurement techniques for viscosity coefficients
  • Learn about the mathematical derivation of shear stress equations
  • Investigate the differences between Newtonian and non-Newtonian fluids
Fluid dynamics engineers, researchers in material science, and students studying rheology will benefit from this discussion.
v_pino
What is the difference between strain rate and velocity gradient of a Newtonian fluid?
For a Newtonian fluid, they are the same, which is proportional to the the shear stress. They are proportional by the second viscosity coefficient. For example, the normal shear stress in the x-direction is given by:
[tex]\tau_{xx} = \lambda (\vec{\nabla}\cdot\vec{V})+2\mu\frac{\partial u}{\partial x}[/tex]
You can see the velocity gradient term in there, with the leading coefficient being the proportional part. Do note that [tex]\lambda[/tex] is hard to measure, and this is where Stoke's Hypothesis (see number fudge so the equations can be solved) comes into play, where we just assume that:
[tex]\lambda = -\frac{2}{3}\mu[/tex]
17K
