Thread Closed
Basis of a vector space proof
Share Thread
Nov11-08, 07:38 PM   #1
Let V be a vector space, and suppose {v_1,...,v_n} (all vectors) form a basis for V. Let V* denote the set of all linear transformations from V to R. (I know from previous work that V* is a vector space). Define f_i as an element of V* by:
f_i(a_1*v_1 + a_*v_2 + ... +a_n*v_n) = a_i
Prove that {f_1,...,f_n} gives a basis for V*.
2. Relevant equations
A basis of a subspace is a set of vectors that are linearly independent and span the subspace.
3. The attempt at a solution
By a theorem from my book, I know that for two subspaces V and W, dim V = dim W implies V = W. Since the basis for V has n vectors, dim(V) = n. Also, dim(R^n) = n. Thus, V can be equated with R^n. Since all vectors in V are in R^n, any linear transformation from V to R must have a corresponding 1xn matrix, so we know that f_1 through f_n have corresponding 1xn matrices. Since we can take the transpose of these matrices to form vectors in R^n, we can easily equate V* to R^n, so dim V* = n. This is another theorem from the book:
Let V be any k-dimensional subspace in R^n. Then any k vectors that span V must be linearly independent and any k linearly independent vectors in V must span V.
Now to finish up, I need to show that either {f_1,...,f_n} span V or they are linearly independent. I'm having trouble with either of those, though, since I don't have an explicit matrix form for any of the functions. All I know is that f_i gives the ith coordinate of a vector in V. I can prove linear independence by showing that:
c_1*[f_1] + c_2*[f_2] + ... + c_n*[f_n] = [0] implies c_1 = c_2 = ... = c_n = 0.
All I can think of from here is to multiply both sides by (a_1*v_1 + a_*v_2 + ... +a_n*v_n) to get:
c_1*a_1 + c_2*a_2 + ... + c_n*a_n = 0.
But I think I must have made an error somewhere, because we can easily show that that equation does not imply that c_1 = ... = c_n = 0.Can somebody please point me in the right direction?
Also, have I made any errors in my proof so far?
Thanks.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Nov11-08, 08:23 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
You can think about this a lot more directly, without dragging matrices into it. You want to show if f is any element of V* then you can express it as a sum of the f_i, right? Consider the constants f(v_i)=a_i. Can you think of a way to use those to express f as a sum of the f_i? Remember if two elements of V* have the same value for all of the basis vectors, they have the same value for any vector. That shows they span. Now suppose the sum of c_i*f_i=f=0. Can you show that that implies that all of the c_i are zero? What for example is f(v_1)? That would show they are linearly independent.
Nov11-08, 08:49 PM   #3
How do I determine what f(v_1) is if all I know about f is that it takes v_1 from V to R?
Nov11-08, 08:55 PM   #4
Recognitions:
I said, suppose f=sum c_i*f_i. Then what is f(v_1)? Of course you can't say much if f is ANYTHING.
Nov11-08, 09:10 PM   #5
OK, I think I got it. We have f(v_i) = c_i, so if we take the equation c_1*f_1 + c_2*f_2 + ... + c_n*f_n = 0 and we multiply by c_i, we get c_i = 0, thus implying that {f_1,...,f_n} is linearly independent.
I'm having trouble with your proof that they span, though. When you said "f(v_i)=a_i" did you mean to write "f_i(a_i*v_i) = a_i"?
Nov11-08, 09:31 PM   #6
Ah, never mind. I figured it out. Thank you very much for your help.
I have one more related problem:
Assume that V is a finite-dimensional vector space, and V* is defined as above. Prove that dim V = dim V*.
I know that I can prove this if V is defined as in the previous problem, but I'm getting tripped up by the fact that a vector space can contain things like functions and matrices.
Nov11-08, 09:57 PM   #7
Recognitions:
You've shown that if v_i is a basis of V, then f_i is a basis of V*, right? There's the same number of v's as f's isn't there?
Nov11-08, 10:42 PM   #8
Oh, that is much simpler than I was trying to make it. Thank you very much for your help.
Thread Closed
Similar discussions for: Basis of a vector space proof
Thread Forum Replies
Basis of a vector space Calculus & Beyond Homework 11
Basis of a vector space Linear & Abstract Algebra 10
Basis for a Vector space Calculus & Beyond Homework 7
Vector Space: Basis Linear & Abstract Algebra 8
Find a basis for vector space Introductory Physics Homework 2
