Ensuring Continuity: Finding the Sum of a and b for a Continuous Function
The discussion revolves around ensuring the continuity of a function defined as the product of two functions, f(x) and g(x), where f(x) is a quadratic function and g(x) involves a limit that introduces potential discontinuities based on the value of x relative to b. Participants are tasked with finding the values of a and b that allow for continuity across all x.
  • Participants explore the conditions for continuity and discuss the implications of the limit in g(x) that leads to discontinuity at specific points. Questions arise about how to determine the values of a and b based on the behavior of the functions near these critical points.
The discussion is active, with participants sharing insights about the nature of continuity and the specific points where discontinuity occurs. Some have proposed equations based on the continuity conditions, while others are questioning the correctness of their assumptions and calculations.
There is an ongoing examination of the relationship between the values of f at the points b-1 and b+1, with some participants noting the need for these values to be equal for continuity, while others are reconsidering their earlier conclusions about the values of a and b.
asd1249jf
[tex]f(x) = x^2 - 4x + a[/tex]
[tex]g(x) = \lim_{n\rightarrow\infty} \frac {2|x-b|^n + 1}{|x-b|^n + 1}[/tex]
let [tex]h(x) = f(x)g(x)[/tex]
Find the sum of a+b that makes h(x) continuous for all x.
Power Series? Derivation to test continuity?
Well I know a function is continuous if
1)f(c) exists
2)Limit as x goes to c of f(x) exists
3)#1 is equal to #2
But I don't know where to go from here. Please help.
How does it fail to be continuous? f(x) is continuous for all a, but g(x) has a jump from when |x-b| < 1 (in which case g(x)=1) to when |x-b|>1 (in which case g(x)=2). So you need to figure out how to take care of it.
I understood why the discontinuity occurs, since |x-b|^n of n to the infinity could take you to 0 or a huge value (I think it was related to geometrical sum) depending on whether it's smaller than 1 or bigger than 1. I still do not have a clue how to get the specific values of a and b from it...
So, for f(x)g(x) to be continuous, you know that when |x-b| isn't near 1, the function's continuous. You should realize this gives us that the only two points of concern are x=b+1 and x=b-1. You have that as x approaches b+1 and b-1 from different sides, g is either 2 or 1. So you need f(b+1) and f(b-1) to be values such that f(b-1)*2=f(b-1)*1 and f(b+1)*2=f(b+1)
Then that simply means
f(b-1) = 1
f(b+1) = 1
So we have
[tex]1 = (b-1)^2 - 4(b-1) + a[/tex]
[tex]1 = (b+1)^2 - 4(b+1) + a[/tex]
[tex]0 = (b-1)^2 - 4(b-1) - (b+1)^2 + 4(b+1)[/tex]
[tex]0 = (b-1)^2 - (b+1)^2 + 8[/tex]
[tex]b = 2[/tex]
Then,
[tex]1 = (2+1)^2 - 4(2+1) + a[/tex]
[tex]1 = 9 - 12+ a[/tex]
[tex]a = 4[/tex]
a + b = 6 is what I get, but supposedly this isn't the answer. I don't see what went wrong here, everything seems right.
[Edit]
Actually, I thought about it, but for the two distinct points of x = b-1 and x = b+1 to be continuous, shouldn't that mean that
f(b-1) = f(b+1) ?
f(b-1)=1. Then 2*f(b-1)=f(b-1) gives us 2=1. Are you sure that's the right value?
f(b-1) and f(b+1) have nothing to do with each other really (although it is correct that f(b-1)=f(b+1) is necessary, this is more by coincidence than any deep connection).
[Edit]
Oh, it's actually
f(b-1) = 0
f(b+1) = 0
Doh! Thx
  • · Replies 20 ·
  • · Replies 40 ·
  • · Replies 27 ·
