Help with intensity formula for n slits interference
The discussion revolves around deriving the intensity formula for interference patterns created by multiple slits, specifically focusing on the transition from the double slit to the n-slit scenario. The original poster expresses confusion regarding the relationship between the two cases and seeks assistance in understanding the relevant equations.
  • Participants explore the mathematical representation of electric fields for n slits and how it relates to the intensity formula. Questions arise about the derivation of specific equations and the meaning of certain terms, such as the real part of complex numbers.
Some participants have provided mathematical expressions and insights into the derivation process. There is an acknowledgment of a specific equation from the textbook that relates to the n-slit case. However, the discussion remains open-ended, with ongoing inquiries about the derivation and application of the formulas.
The original poster references a specific textbook for equations and expresses a need for clarification on certain terms and concepts. There is an indication of a reliance on textbook resources for understanding the problem context.
helloeveryone
somebody help me, i have a homework question: obtaining the formula of calculating the intensity of n slits interfenrece.
the only source is the formula to calculate the intensity of double split interference: I/Io = (E/Eo)^2, and I = 4Io(cos(pie d... (equation 41-7 physics textbook of 5th edition by halliday, and resnick and Krane)
I tried everything in my power but it hopeless, i couldn't see the connection between n slits and 2 slits, help me out, thanx
For n slits,
[tex]E(t) = E_0 \left[ \cos\omega t + \cos(\omega t +\phi) + ... + \cos\{\omega t + (n-1) \phi\}\right] = E_0 \left[\sum_{k=0}^{n-1} \cos(\omega t + k\phi) \right][/tex]
where [tex]\phi = \frac {2 \pi d \sin \theta}{\lambda}[/tex]
Note that
[tex]\displaystyle{\sum_{k=0}^{n-1} \cos(\omega t + k\phi) = \Re\left[ \sum_{k=0}^{n-1} e^{i(\omega t + k\phi)}\right] = \Re\left[ e^{i\omega t}\sum_{k=0}^{n-1} e^{i k\phi}\right] = \Re\left[e^{i\omega t} \frac{1-e^{in\phi}}{1-e^{i\phi}}\right] = \Re\left[e^{i(\omega t + \frac{n-1}{2} \phi)} \frac{e^{i\frac{n}{2}\phi}-e^{-i\frac{n}{2}\phi}}{e^{i\frac{1}{2}\phi}-e^{-i\frac{1}{2}\phi}}\right]}[/tex]
[tex]= \displaystyle{\Re \left[e^{i(\omega t + \frac{n-1}{2} \phi)} \frac{\frac{e^{i\frac{n}{2}\phi}-e^{-i\frac{n}{2}\phi}}{2i}}{\frac{e^{i\frac{1}{2}\phi}-e^{-i\frac{1}{2}\phi}}{2i}} \right] = \Re \left[e^{i(\omega t + \frac{n-1}{2} \phi)} \frac{\sin \frac{n}{2}\phi}{\sin \frac{1}{2}\phi}\right] = \frac{\sin \frac{n}{2}\phi}{\sin \frac{1}{2}\phi} \cos \left(\omega t + \frac{n-1}{2} \phi\right)}[/tex]
I guess you can work out the rest using the above equation?
thanx you so much for helpin me out. if you help me, you mind to help me a bit more: could you tell me how you obtain the formula above (you don't have to write everything in detail, just give me the source that you get the formula, or just give any formula that involve that formula above (is it the formula in the textbook?). And one last thing, what is R value in the note.
oh, nvm, i got it, that was the equation 41-6 in the textbook for n slits.
If i am not mistake, the rest thing i have to do is use equation I(t)/Io = (E(t)/Eo)^2 to find out I(t)
man, your'e genius, lifesaver, i love u man
You flatter me.
R just means the real part of a complex number, and e^ix = cos(x) + i*sin(x) was used in the above equation.
For the answer, I think you need to drop out the cos(omega*t + phase) part to get the amplitude(rather than the full time dependence of the electric field).
  • · Replies 19 ·
  • · Replies 17 ·
