Thread Closed
Center of mass of physical pendulum
Share Thread Thread Tools
Nov13-08, 09:22 PM   #1
A pendulum consists of a uniform disk with radius r=0.100m and mass 0.500 kg attached to the end of a uniform rod with length L=0.500 m and m 0.250 kg. It pivots at the other end of the rod. a) Calculate the rotational inertia of the pendulum about the pivot point. b) What is the distance between the pivot point and the center of mass of the pendulum? c)Calculate the period of oscillation
2. Relevant equations
I=Icom+mh^2
T=2pi(sqrt(I/(mgh)))
3. The attempt at a solution
I got the first part using the parallel axis theorum for both the disk and the rod and adding them together. I=0.205 kg*m^2 (checked, correct).
I can't figure out how to get the distance between the pivot point without having the period. I tried setting I=mL^2 and solving for L, but this was incorrect. The correct answer is 0.477 m. I can get part c) once I have some clues to b. I'm completely lost. Please help!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Nov14-08, 09:42 AM   #2
So I take it no one else can figure this one out either?
Nov14-08, 10:10 AM   #3
Recognitions:
Homework Helper Homework Help
Quote by burianek View Post
I=Icom+mh^2
Where is the center of mass of the disk? Where is it for the rod? Once you have those two, you can use the standard center of mass formula to find the center of mass of the entire object.
Thread Closed
Tags
center of mass, physical pendulum
Thread Tools
Similar Threads for: Center of mass of physical pendulum
Thread Forum Replies
Simple Pendulum Motion and Physical Pendulum Introductory Physics Homework 6
among Simple harmonic oscillation, simple pendulum and physical pendulum Introductory Physics Homework 10
Center of mass/pendulum Introductory Physics Homework 2
Help with problem of Center of mass, linear mass density and total mass Introductory Physics Homework 1
The center of Mass perfectly match the center of Force-> General Physics 9
