Solve Tricky Continuity Homework Statement
  • Thread starter Thread starter squaremeplz
    Continuity
The discussion revolves around two continuity-related problems. The first problem involves demonstrating the existence of a point \( x \) in the interval \([0, \pi/2]\) such that \( x = \cos(x)^2 \). The second problem requires showing that for a continuous function \( f \) at a point \( c \) where \( f(c) = 1 \), there exists some \( a > 0 \) such that \( f(x) > 1/2 \) whenever \( |x-c| < a \).
  • Participants discuss the application of the Intermediate Value Theorem in the first problem, questioning the plausibility of the original poster's reasoning. There is also a suggestion to consider the function \( g(x) = x - \cos(x)^2 \) to show that it has a zero in the interval. In the second problem, a participant references the definition of continuity and suggests using \( \epsilon = 1/2 \) to approach the problem.
The discussion is ongoing, with participants exploring different approaches to both problems. Some guidance has been offered regarding the continuity definition and the use of the Intermediate Value Theorem, but there is no explicit consensus on the correctness of the original poster's attempts.
Participants express uncertainty about their reasoning and seek clarification on their approaches. The original poster has indicated a lack of confidence in their solution, particularly for the first problem.
squaremeplz
1. show there is some point x in the interval [0,pi/2] so that x = cos(x)^2
2. let f:R-> be continuous at c and suppose f(c) =1. show that there is some a > 0 such
that f(x) > 1/2 whenever |x-c| < a
intermediate value theorem. maximum minum
1. We know that f(x) = cos(x)^2 assumes its max value at f(0) = 1 and its min. at f(pi/2) = 0
by the int. value theoreom 0 < pi/2 implies f(pi/2) < y < f(0)
implies for some z in [0,pi/2] f(z) = y
the only conclusion I can come up with is that since the interval [0,pi/2] is greater than the distance between |f(0)-f(pi/2)| there has to be at least one x in [0,pi/2] where f(x) = x. Is this plausible?
b) Unsure as to how to properly approach this problem.
since f(x) > 1/2
|f(x) - f(c)| = |1/2 - 1| <= |1/2| < e/2
let a equal e/2?
I truly apologize for this poor approach. If someone could just direct me in the right direction it would be greatly appreciated.
Why not just the basic definition of continuity?
If f is continuous at c, then, given any [itex]\epsilon> 0[/itex], there exist [itex]\delta>0[/itex] such that if [itex]|x- c|< \delta[/itex], then [/itex]|f(x)- f(c)|< \epsilon[/itex].
Take [itex]\epsilon= 1/2[/itex].
was part 1. correct? I still feel a bit insecure about my answer. thanks
Yes, part 1 is correct.
Your proof of part 1 is a little confusing. Consider the function g(x)=x-cos(x)^2. Can you show g(x) has a zero in [0,pi/2]?
  • · Replies 40 ·
