What is the real component of complex products in quantum mechanics?
  • Thread starter Thread starter kasse
    Complex Product
The discussion revolves around the calculation of the real component of complex products in quantum mechanics, specifically involving exponential functions of energy terms.
  • Mathematical reasoning, Problem interpretation
  • Participants explore the multiplication of complex exponentials and the conversion to trigonometric forms. There is a focus on ensuring the correct number of terms in the expansion and the proper application of exponential properties.
Some participants have provided guidance on the multiplication process and the interpretation of results. There appears to be a progression in understanding as participants clarify their approaches and confirm corrections.
There is an emphasis on the accuracy of mathematical operations and the interpretation of complex numbers in the context of quantum mechanics. Participants are working within the constraints of homework guidelines that require careful reasoning without providing direct solutions.
kasse
[tex]Re [e^{iE_{0}t/\hbar} \cdot e^{-iE_{1}t/\hbar}] = Re[ e^\frac{it}{\hbar}(E_{0}-E_{1})] = cos \frac{t}{\hbar}(E_{o}-E_{1})[/tex]
Correct?
Check your multiplication. You ended up with two terms, each with two factors. You should have ended up with four terms, each with two factors.
Another approach is to multiply the two exponentials first before converting them to cos X + i sin X. Remember that e^A * e^B = e^(A + B).
I've updated it. Is this what you meant?
That's what I meant in "another approach." Also, your answer looks to be correct this time.
  • · Replies 0 ·
