| Thread Closed |
Al 6061 wear properties- help |
Share Thread | Thread Tools |
| Nov14-08, 01:23 PM | #1 |
Hello,
Did some wear experiments on some Al 6061 samples. Could anyone help with some microstructure descriptions (changes) and why oxygen should appear in the EDS of severe wear (70N at a sliding distance of 3000M)? Also if anyone has any papers on wear reistance or coefficient of friction I sure would appreciate it. Cheers |
| Nov20-08, 07:05 PM | #2 |
If you exposed the aluminum to air at all following the wear, I would expect oxygen in the EDS signal. Aluminum oxides rapidly, and if you're doing EDS on the surface, there will be a thin layer of Al2O3.
I'm not sure what you mean by microstructure descriptions. |
| Nov22-08, 09:35 AM | #3 |
Thank you.
If it's been slided against a steel ring, wouldn't metal transfer during severe wear cause Iron Oxide to appear on the Al surface? Thanks |
| Nov26-08, 10:51 PM | #4 |
I would actually expect aluminum (and therefore aluminum oxide) to appear on the steel surface. The steel is presumably much harder than the aluminum. Because of this, a wear process would wear away the aluminum, leaving the steel mostly intact.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Al 6061 wear properties- help
| Do you wear glasses? | General Discussion | 16 | ||
| How does the properties of glass affect its properties?? | General Physics | 3 | ||
| Wear it | General Discussion | 22 | ||
| Like OMG, what should I wear?!?!?!?! | General Discussion | 41 | ||
