Projectile Motion with a Spring
The discussion revolves around deriving equations to predict the travel distance of a steel ball launched horizontally from a spring launcher. Participants explore various approaches, assumptions, and corrections related to the physics of projectile motion and spring mechanics.
  • One participant seeks help in deriving a single equation for the distance a steel ball travels when launched horizontally from a spring launcher.
  • Another participant suggests defining the system completely, including height, spring constant, and spring compression, and proposes an approximate range formula that factors in these variables.
  • A different approach is presented, recommending a vertical launch test to measure maximum height, which can then be used to calculate the range for horizontal launch.
  • Another participant discusses calculating the acceleration of the ball while in contact with the spring using Hooke's law and Newton's second law, leading to a proposed range calculation that assumes ideal conditions.
  • A critique is raised regarding the assumption of uniform acceleration during the spring's contact with the ball, noting that acceleration varies harmonically, suggesting a more complex analysis is needed.
  • One participant attempts to refine the model by considering harmonic motion and presents a modified equation for range, questioning its correctness.
  • A new scenario is introduced involving a tennis ball launched at an angle, with empirical results that differ from theoretical predictions, prompting a need to calculate the spring constant and expected landing distance.
Participants express differing views on the assumptions regarding acceleration during the launch, with some proposing simplified models while others argue for more complex, accurate representations. The discussion remains unresolved with multiple competing approaches and no consensus on the best method.
Limitations include assumptions about ideal conditions, such as neglecting air resistance and the uniformity of acceleration, which may not hold true in practical scenarios. The discussion also highlights the dependence on specific parameters like spring constant and launch height.
This discussion may be useful for individuals interested in physics, particularly those exploring projectile motion, spring mechanics, and experimental validation of theoretical models.
Bouncingball
Im having a little trouble deriving a single equation that will predict the travel distance of a steel ball launched by a horzontal spring launcher. The spring launcher doesn't launch at an angle. Any help on this would be appreciated. Thanx
Define the system completely.
Is the launcher some height above the ground ?
Do you know the spring constant ?
Do you want to find the distance as a function of the compression of the spring ?
Assuming answers are YES, YES and YES...the following should work approximately :
Range = d*SQRT(2hk/mg),
where d : size of spring compression = uncompressed length - compressed length
h : height of launcher from ground
k : spring constant, and
m : mass of the steel ball
You will probably find, that the real range will be less than the above predicted value, because
1. of air resistance, and
2. some residual energy in the spring after launch
Both these corrections can be calculated for a more accurate answer.
A more accurate answer can be had by doing a simple test lanch first. Point your launcher vertically upwards and measure the maximum height reached by the ball from the end of the spring. Call this height, H. Then the range for the horizontal launch will be :
Range = SQRT(4*H*h)
This removes nearly all the error from 2. above, and some of the error from 1.
Firstly, i imagine you know the spring constant of the spring, if not, you can work it out using simple harmonic motion equations.
Once you know this, you can begin to work out its acceleration as it is in contact with the spring. This can be done by using the eqations:
[tex]F=-kl[/tex]
(where k is the spring constant and l is the distance you pull the spring back)
By then applying [tex]F=ma[/tex]:
[tex]-kl=ma[/tex]
you can find the acceleration relatively easily:
[tex]a=\frac{-kl}{m}[/tex]
Then it would just be a case of using suvat equations:
[tex]v^2=u^2+2as[/tex]
[tex]v=?[/tex]
[tex]s=l[/tex]
[tex]u=0[/tex]
[tex]a=-kl/m[/tex]
once you have found v, you can use projectile methods to calculate how far it will travel:
You will know, or be able to measure the height of the apparatus, so using suvats you can work out how long it would take to hit the floor (let the previous value of v be u now):
[tex]s=0.5a(t^2)[/tex]
[tex]s=h[/tex]
[tex]a=g[/tex]
[tex]t=?[/tex]
[tex]h=0.5g(t^2)[/tex]
[tex]t=\sqrt{2h/g}[/tex]
As the value of t is common in both components, you can substitute it in for the horizontal component, hence to find how far it will travel:
[tex]range=u[/tex]
[tex]range=2l\sqrt{\frac{4kh}{mg}}[/tex]
ignoring air resistance and assuming the spring is smooth. (hence an ideal situation)
I think this is right. Although it might not be. So use it if you want.
Yes youth, tweak
The problem with this approach is that you assume there is a inform acceleration during the time the ball is in contact with the spring. This is not true. The acceleartion varies harmonically. But you can still find v by solving the equation of motion of a mass loaded spring (need damping to be accurate).
To eradicate this problematic approach, i will consider the spring moving harmonically:
here goes
[tex]a = -\omega^2 l sin\omegaT[/tex]
[tex]a = -\omega^2 d[/tex]
[tex]a = -\Frac{k}{m} d[/tex]
[tex]T = \frac{2pi}{\omega}[/tex]
[tex]d = \frac{1}{l sin \frac{\frac{-k}{m}\frac{2}{\pi}}{\sqrt{\frac{k}{m}}}}[/tex]
my previouse equation:
[tex]l\sqrt{\frac{4kh}{mg}}[/tex]
Replace l with d:
[tex]Range = \frac{\sqrt{\frac{4kh}{mg}}}{ - l sin \frac{2\pi\sqrt{k}}{m}}}[/tex]
Is this right?
I don't know. Hopefully!
Okay, same problem, but this time it's a tennis ball and it's launched at a 30deg. angle. In addition, the mass of the ball is 5oz./0.14kg, launch height is 10.25ft. above ground where target is 50.25ft. away horizontally. Theoretically, the ball should hit the target, but ours hit at 2'11", 7'6", 16'1", and 38'2" horizontally, with an average of 20'7".
Need to calculate the spring constant K from this, plus a visual calculation of where to "expect" it to land, if the testing hadn't actually been done.
  • · Replies 16 ·
20K
  • · Replies 25 ·
