Thread Closed
Beam under a distributed load
Share Thread Thread Tools
Nov14-08, 08:29 PM   #1
A simple beam is under a distributed load q=c*sine(n*pi*x/L)? if there are two pivots at the end points supporting it, what will be the reactionary force on each one of them?
Here, L is the length of the beam and x=0 is the leftmost point. 0[tex]\leq[/tex]x[tex]\leq[/tex]L
The figure looks like this.
___________________
2. Relevant equations
3. The attempt at a solution
I cannot figure out how to approach to this problem. can you please help me ?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Nov14-08, 09:00 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by koolsid View Post
___________________
How's your calculus (better than mine, I hope)? Start by integrating the load distribution from 0 to L to solve for the total load, which acts at the centroid of the sinusoidal load distribution. Then what?
Nov15-08, 08:41 AM   #3
yes, but the problem is what to do with 'n'? it can change also....wat if n is odd and n is even?
Nov15-08, 01:40 PM   #4
Recognitions:
Yes, good point, that n makes it more difficult. When n is an integer greater than 1, the distributed load curve crosses the x axis, so integrating the load curve from end to end will not help in determining the reactions. It looks like you have to perform separate integrations between n segments that are each (1/n)L in length, then place the load at the centroid of each section to get the end reactions. There's probably a formula to calculate this, but I don't know what it is.
Nov15-08, 08:20 PM   #5
When n is an integer greater than 1, the distributed load curve crosses the x axis can u tell me in detail this point
Nov15-08, 09:50 PM   #6
Recognitions:
it crosses at q=0, that is, when sin(n)(pi)x/l = 0, which occurs at x=0, and l/2 when n=2, at x=0, l/3, and 2l/3 when x=3, and in general, at x=0, l/n, .......(n-1)l/n.
Nov15-08, 11:45 PM   #7
can u tell me where will be the centroid means how to calculate centroid for this case?
Nov16-08, 10:17 AM   #8
where is the centroid for this case?
Thread Closed
Thread Tools
Similar Threads for: Beam under a distributed load
Thread Forum Replies
Do you calculate the amount of load a beam can take based on when the beam cracks? Materials & Chemical Engineering 6
beam maximum load Materials & Chemical Engineering 5
Torque on a Massful Beam with Load Introductory Physics Homework 4
Distributed load and stress General Engineering 6
What height beam do I need to support a weight? Howto calc horiz load? General Engineering 4
