Is Consciousness Found in Everything in the Universe?
  • Thread starter Thread starter Holocene
    Observer Physics
The discussion revolves around the nature of consciousness and its potential relationship with quantum mechanics, exploring whether a new scientific discipline beyond neurophysiology is necessary to understand consciousness. Participants delve into philosophical implications, the role of quantum processes in the brain, and the concept of panpsychism, which suggests a form of consciousness may exist in all matter.
  • Some participants propose that understanding consciousness may require a new scientific approach beyond neurophysiology, considering its complex nature and potential connections to quantum mechanics.
  • Others argue against the necessity of a quantum framework for consciousness, suggesting that the brain processes information in a non-quantum manner and that superpositions may not significantly influence cognitive functions.
  • A participant raises the idea that consciousness could be a fundamental property of the universe, potentially shared by all matter, aligning with panpsychism.
  • Another viewpoint suggests that consciousness should not be viewed as a quasi-religious entity but rather as a phenomenon that can be modeled mathematically, with implications for understanding complex structures like quasars.
  • Some participants discuss the implications of consciousness in artificial intelligence, speculating that computers may eventually surpass human cognitive abilities.
  • There is a suggestion that the brain's processing capabilities may involve quantum processes, but these may not be significant at the macro level.
  • One participant draws parallels between the growth of crystals and the evolution of consciousness, proposing that even simple structures exhibit primitive forms of awareness.
Participants express a range of views on the nature of consciousness, with no consensus reached. Some support the idea of panpsychism, while others challenge the relevance of quantum mechanics to consciousness. The discussion remains unresolved regarding the necessity of a new scientific discipline for understanding consciousness.
Participants highlight various assumptions, such as the definitions of consciousness and awareness, and the potential limitations of current scientific frameworks in addressing these concepts. The discussion also reflects differing interpretations of quantum mechanics and its implications for cognitive processes.
Holocene
Sorry if this is more of a philosohpical question, but
With both the strange perplexity and proven aspects of quantum mechanics in mind, do you think we will ultimetly need to devote a science beyond even neurophysiology to understanding what consciousness really is?
I don't think so. The way it looks today, is that another persons mind will end up in a density matrix state were it believes A or B with a certain probability, and we'll have the small field of quantum conscience where we see how algorithms or minds or whatever can hold entangled states and superpositions and make use of them. It doesn't look too useful right now, so I don't think there is a need for quantum computation as a discipline outside of computer science. But to paraphrase von Neuman "These predictions always look silly in retrospective."
The only question that is really crazy is: If you look into your brain, and observe the states, will it look like your brain is the only one that doesn't do superpositions?
I don't think it's wise to blend 'digital' states with analogue.
Your consciousness works with an awful lot of information every 'instant' sorting out what is important for you.
It does not work at a 'bit state'/'rate'.
The brain is not 'digital' and it's not 'bit by bit' serial..
Even when you read about 'quadra core' CPU:s
It's still serial signal processing inside it and out on the buss(es).
The brain is more like analogue.
Containing a high ratio of simultaneous 'noise' aka information.
And the brain sorts that out.
At all times, although adapting to your 'needs' like sleeping hunting etc.
This site gives a good example on it when it tries to guess/translate our eyes visual information to 'Digital'.
http://www.wdv.com/Eye/EyeBandwidth/
Reading Mister Warren you might find him confusing at times:)
I did too. So I tried to translate his equations into pixels here.
1 Petabytes = 1000 terabytes where every terabyte represents 1000 gigabytes
So 4000 Terabytes times 1000 = 4 000000 gigabytes, where 1 gigabyte is 1024 Megabytes
So counted that way we have four millions times 1024 = 4096000000 mega bytes
4096000000 megabytes times 1024 is 4194304000000 kilo bytes
And (as one Kilobyte = 1024 bytes) then 4194304000000 times 1024 will give us 4294967296000000 bytes
And it takes approximately 3 bytes to characterize each pixel if I got it right.
That as every pixel is made up of R,G,and B channels and requires one byte for each channel.
("Therefore, one pixel is 3 bytes, 1 megapixel is 3 megabytes etc."
But that is not really correct as one megabyte is 1024 times 1024 bytes = 1048576 bytes (times eight bits) digitaly.
And one megapixel is 1000000 pixels so one million pixels should then be three million bytes.
That translates to 145728 bytes less than three megabytes.
If one had said megabit instead of megabyte it would be correct though.
That as one megabit is 1 000 000 bits)
So when we split 4294967296000000 bytes in three it will give us 1431655 765 333333,3333333333333333 pixels for a two hour movie.
And that I won't even try to write out in letters.
If I got it right this time?
and two hours is 7200 seconds split with 1431655 765 333333,3333333333333333 give 198841078518,51851851851851851852 pixels per second.
Yes definitley - consciousness has long been neglected as a 'law of physics' so to speak.
Too often has it been regarded as a quasi religeous entity rather than phenomenonlogically.
For example, knowledge arising from consciouness can mathematically model and explain the causal structure of a Quasar that looks like a tiny star, but is in fact a collapsing galaxy over the other side of the Universe.
Its a simply enormous power - consciousness, the Quasar cannot model us, but we can *contain* the essence of the Quasar here in the solar system.
I view it as important to start modelling consciousness itself. For example, will computers eventually have the same consciousness power as brains - biological computers?
I always said against fierce opposition that computers would eventually be better at chess than humans. It came to pass. And I am saying the same with consciousness - computers will eventually out perform us in discovery etc. Sorry if you think we are *special*, its consciousness that is special and is a property of the Universe somehow.
Wish I knew exactly how.
Hmmm interesting thought. My take is that the brain must be doing superpositions to process information but the results are macro, so that those superpositions don't influence the process. For example, thowing a die - quantum processes are there, yes, but its a large scale happening where the superpositions are too small to influence the results.
Secondly, our brain has a lot to do with information processing - and as far as I know the quantum superposition is not significant. 1s and 0s don't have a quantum aspect because they are made by macro processes where the superpostion does not play a role. For example an abacus is a macro tool. Or what about adding 1s and 0s on paper - again no superposition involved here. I suspect the same is true in the brain - but I am not sure.
One could argue that space time itself is a delusion, and that information processing is a participant in this delusion in some sense. But that is off the thread topic I think.
Panpsychism is becoming more prevalent in the literature. On a very, very primeaval level, isn't it possible that mass itself is conscious? That is, defining life as an ":awareness" (self to otherness, observer to observed, etc.) suggests water has an "awareness" to always boil at 100 degC. Or are humans so arrogant that only they have "feelings"..??
I agree - consider crystal growth - a crystal grows only itself (like life) and in solution will bend towards regions of high concentration (of itself). Crystals bending could be considered as primitive intelligence, even though it is only occurring because the chemical is more on one side than the other. A complex structure like the eye is based on one cell that is sensitive to light, then over time it becomes dish shaped - etc etc until an eye is formed by evolution. The brain similarly evolved from stages of complexity - a very complex 'crystal bending' phenomenon - rather than some 'soul' at work.
The Universe is 'aware' - that's a wonderful idea. There is an old German saying that even objects have a phsyche.
Newton studied Alchemy in a desperate attempt to find the link between life and inanimate chemicals. After studying metallurgy - crystal growth- he concluded not very much, unfortunately, EXCEPT, that 'the Universe is straining towards intelligence' which for me is the hammer idea.
Two fundamental factors to create life are forces -that bring like chemicals together and topology - that defines which chemicals link to other chemicals. Almost back to our old friend - symmetry eh?
  • · Replies 81 ·
9K
  • · Replies 62 ·
14K
  • · Replies 16 ·
  • · Replies 40 ·
