Proving Continuity for h(x) = x^x = e^xlnx, Given f(x) = e^x and g(x) = lnx
  • Thread starter Thread starter kathrynag
    Continuity
The discussion revolves around proving the continuity of the function h(x) = x^x, which is expressed in terms of two other functions: f(x) = e^x and g(x) = lnx. The focus is on the continuity of h(x) for x > 0, given that f and g are continuous.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the relationship between h(x) and the composition of f and g, questioning whether h(x) can be expressed as f(g(x)).
  • Some participants discuss the implications of continuity for the product of functions and how that relates to the continuity of h(x).
  • There are attempts to formulate an epsilon-delta proof, with participants raising questions about variable usage and connections between different parts of the proof.
The discussion is active, with participants providing guidance on the continuity of composite functions and the product of continuous functions. There is a focus on clarifying the use of variables in the context of epsilon-delta proofs, indicating a productive exploration of the topic.
Participants are navigating the complexities of continuity proofs and are considering the implications of continuity for the functions involved. There is an emphasis on ensuring that variable assignments do not lead to confusion in the proof process.
kathrynag
f(x)=e^x
g(x)=lnx
h(x)=x^x=e^xlnx
If f and g are continuous prove h(x) is continious for x>0
Ok this confuses me, because I would think that it wouldn't be too bad too do if h(x)=f(g(x)). Maybe the book had a typo?
this is just f(x*g(x)). What do you know about x*g(x) if g is continuous?
Then lx-x0l<[tex]\delta[/tex]
Then lxg(x)-x[tex]_{0}g(x_{0})[/tex]l<[tex]\epsilon[/tex]
Hmm well if you've proved that the product of two continuous functions is continuous (which is easy, provided that you know the proof that the limit of a product is the product of limits), then I don't think you need to resort to epsilon delta for x*g(x).
Also, f is continuous, so basically you have a lot of continuous functions involved in different operations. If you've already proved that f(g(x)) is continuous at a point a if g(x) is continuous at a and f is continuous at g(a), then you could save yourself a lot of trouble.
Ok, how do I do that epsilon delta proof?
lx-al<[tex]\delta[/tex]
lg(x)-g(a)l<[tex]\epsilon[/tex]
f continuous at g(a)
lx-g(a)l<[tex]\delta[/tex]
lf(x)-f(g(a)l<[tex]\epsilon[/tex]
A few comments to point you in the right direction. We want |x-a|<[tex]\delta[/tex] to imply that lf(g(x))-f(g(a)l<[tex]\epsilon[/tex].
This is fine, except one variable should be changed. We want to somehow connect this to our second fact, which is
Ok, obviously we want to be careful about using the same variables. Since x is used to represent elements in the domain of g, let's use y to represent the elements in the domain f. Making this change, we have
ly-g(a)l<[tex]\delta[/tex]
lf(y)-f(g(a)l<[tex]\epsilon[/tex]
Now note that if we replace y with g(x), which is certainly allowed, we are very close to what we need. Namely, lg(x)-g(a)l<[tex]\delta[/tex] implies that |f(g(x))-f(g(a)l<[tex]\epsilon[/tex]. But we also know that we reserved the variable delta for lx-al<[tex]\delta[/tex]. So we need to change the delta in lg(x)-g(a)l<[tex]\delta[/tex] to some other variable.
In fact, we can choose any variable that is greater than 0 (Why?). So let's choose d' (delta prime). Now how can we use the fact that d' > 0 to connect our delta in |x-a| < [tex]\delta[/tex] to our epsilon in |f(g(x))-f(g(a)l<[tex]\epsilon[/tex]?
Should it be changed to a f or are you talking about a change from x to y?
Ok so there is d' such that lg(x)-g(a)l<[tex]\delta[/tex]. then |f(g(x))-f(g(a)l<[tex]\epsilon[/tex]
Ok, here's my start:
h(x)=[tex]x^{x}[/tex]
Then h(x)=f(xg(x))
Choose [tex]\epsilon[/tex]<0. There is [tex]\delta_{1}[/tex]>0 such that if [tex]\left|y-x_{0}g(x_{0})\right|[/tex]<[tex]\delta_{1}[/tex].
