Why Is Magnetism Stronger at the Tip of a Tapered Blade?
  • Context: Undergrad
  • Thread starter Thread starter feynomite
    Magnetism Surface
The discussion focuses on the phenomenon of magnetism being stronger at the tip of a tapered blade, specifically a pair of scissors that have been magnetized. Users confirm that the magnetic attraction is significantly greater at the tip due to the concentration of magnetic lines of force, which exit at the ends of the blade. The blade's tapering shape and thickness contribute to this effect, as the magnetic field is more concentrated at the narrower end. The discussion also touches on the implications of altering the blade's shape for enhancing magnetism.
  • Understanding of basic magnetism principles
  • Familiarity with magnetic fields and poles
  • Knowledge of material properties related to magnetization
  • Basic physics concepts regarding force and attraction
  • Research the principles of magnetic field concentration in tapered objects
  • Explore the effects of blade thickness on magnetism
  • Study the process of magnetizing materials and demagnetizing techniques
  • Investigate the relationship between shape and magnetic strength in various materials
Physics enthusiasts, materials scientists, engineers, and anyone interested in the practical applications of magnetism in tools and devices.
feynomite
I have a pair of scissors. The blade is about 1.5 cm wide on one end (near the handle), and it tapers down to nothing after about 7-8cm. The blades are about 3mm in thickness. It's been magnetized, meaning, I guess, I've stuck a magnet on it a few times. I'm exactly sure how or why there is such a lasting residual effect, or how to get rid of it, but that's another topic.
Anyway, when I take something magnetic, like a stainless steel keychain ring, and hold it near the scissors, it is magnetically attracted much more so at the very tip of the scissors rather than anywhere else on the blade. I can tell this by feeling how hard I have to pull to get the keychain away from the scissors. It's much harder to lift it when its stuck to the tip than it is if its just a couple of cm away from the tip. Near the base of the blade it's barely attracted at all. The same applies to the edges of the blade.. it's not attracted to the edge of the blade unless its near the tip.
I wonder, how can the shape of the blade make it more magnetic on one end than the other? What would happen if I made the tip of the blade extremely narrow, would it become infinitely magnetic? Does the blade thickness factor into this, as well?
Thank you all for your input :)
The scissors are magnetized along their length, just like a bar magnet. The magnetic lines of force travel along the metal and exit at the ends, which is why you feel the greatest force there. Here is a diagram showing the concentration of lines at the magnet ends ("poles").
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/elemag.html"
  • · Replies 19 ·
  • · Replies 33 ·
10K
