Greedy Algorithm for license purchase problem
  • Thread starter Thread starter Shaitan00
    Algorithm
The discussion revolves around a problem involving the optimal order of purchasing licenses for cryptographic software, given that the prices of these licenses increase exponentially over time. Participants explore strategies to minimize total costs while adhering to the constraint of buying one license per month.
  • One participant questions whether the order of purchasing licenses affects total cost, suggesting that it may not matter.
  • Another participant argues that the order does matter, providing an example with distinct exponential growth rates for two licenses, emphasizing the importance of timing in purchasing decisions.
  • A different participant attempts to clarify the problem by restating the cost function and the objective of minimizing total costs, proposing a strategy that involves buying the least expensive license last, based on the assumption of exponential growth rates greater than one.
  • Following this, a participant expresses agreement with the proposed strategy of starting from the last month and working backward to choose the least expensive option.
There is no consensus on the optimal purchasing strategy. Some participants believe that the order of purchases is crucial, while others question this assumption. The discussion remains unresolved regarding the best approach to minimize costs.
Participants express uncertainty about the implications of different growth rates and the conditions under which certain strategies may be optimal. The discussion highlights the complexity of the problem due to the distinct exponential growth rates of the licenses.
Shaitan00
Your friends are starting a security company that needs to obtain licenses for n different pieces of cryptographic software. Due to regulations, they can only obtain these licenses at the rate of at most one per month.
Each license is currently selling for a price of $100. However, they are all becoming more expensive according to exponential growth curves: in particular, the cost of license j increases by a factor of rj > 1 each month, where rj is a given parameter. This means that if license j is purchased t months from now, it will cost 100×rtj . We will assume that all the price growth rates are distinct.
The question is: Given that the company can only buy at most one license a month, in which order should it buy the licenses so that the total amount of money it spends is as small as possible?
I think you left something out. Order doesn't seem to make any difference. Am I missing something?
Of course order makes a difference.
Assume I have license 1 with rate t^3 and license 2 with rate 2^t - now these rates are exponential and there is no easy way to determine the correct growth rate (derivates are wrt to "t" as well), so how can you ensure you pick the right one first so that at (t+1) you don't end up having to spend more because license 2 now costs a lot more then license 1 would have?
So, depending on time (t) the price will be different, and seeing as all rates are different some things will become much more expensive then others as time goes on, those should be bought first.
I am not sure if I understood the question properly, so I am expressing what I understand, and you can correct me if there is a misunderstanding.
" A company needs to buy n different software licences. The cost of license type j in month t from a given reference date is given by
C(j,t)=100*r(j)t, j=1...n
where r(j) is the growth factor of the license of type j.
If the company can afford to buy 1 license per month, what is the optimal buying strategy in the choice of the order buying the n licences?
Assume that the company buys the first license at time t=0."
The objective is to minimise
Sum(C(j,t)) for t=0,n-1
by using a logical choice of j each month.
Since it is an exponential function, ASSUMING r(j)>1, its seems logical (to be verified) to use the inverse of the greedy algorithm, namely, pick the least expensive at time t=n-1, n-2, ... etc., i.e. pick the last one first. If r(j)<1, then it is logical to buy the least expensive each month as time goes on (t=0 to t=n-1).
Nope - you pretty hit it right on...
That is what I was thinking also - start at month (n) - the last month - and calculate the rate, then choose the smallest one and buy it, and proced to month (n-1).
Thanks for the confirmation.
Much appreciated.
  • · Replies 46 ·
