Create Matrix without For Loop in MatLab
  • Context: MATLAB
  • Thread starter Thread starter realanony87
    Diagonal matrix Matrix
The discussion revolves around creating a specific matrix structure in MATLAB without using a for loop. The matrix features a pattern of numbers that shifts left in each subsequent row, and participants explore methods to achieve this using MATLAB functions.
  • Technical explanation, Exploratory, Debate/contested
  • One participant seeks a method to create a matrix with a specific pattern without using a for loop.
  • Another participant suggests using diagonal matrices to construct a tridiagonal matrix, proposing the use of the `diag` function to achieve this.
  • A third participant challenges the characterization of the matrix as tridiagonal, noting that the rows are shifted left by one position, which alters the structure.
  • A fourth participant shares a MATLAB script that utilizes `circshift` to create the desired matrix, indicating a willingness to practice coding in MATLAB.
Participants do not reach a consensus on the classification of the matrix as tridiagonal, and there are competing methods proposed for constructing the matrix without a for loop.
There is an assumption that the matrix structure is understood among participants, but the exact requirements for the matrix creation are not fully clarified. The proposed methods may depend on specific definitions of matrix types.
realanony87
I am trying to create the following Matrix without the use of a for loop.
1 2 1 0 0 0 0 0 0 0 0 0
0 0 1 2 1 0 0 0 0 0 0 0
0 0 0 0 1 2 1 0 0 0 0 0
0 0 0 0 0 0 1 2 1 0 0 0
Etc.
Is there a simple way of doing this
Edit: Using Matlab
Are you using Matlab?
You have a tridiagonal matrix so the easiest way to set it up is to add 3 diagonal matrices.
If you have an m-by-m matrix you can write
diag(2*ones(1,m),0) + diag(ones(m-1,1),1) + diag(ones(m-1,1),-1)
Note that this matrix will have a 2 at the first and last position of the main diagonal, but you can easily remove the first and last row.
Well It isn't tridiagonal because every row is shifted to the left by one .
Simply cannot resist the opportunity for me to practise writing a MATLAB script :biggrin:
% will display m by n matrix B that wrapped the elements 1 2 1
m=5; n=10;
A=zeros(1,n);
A(1)=1; A(2)=2; A(3)=1;
for k=1:m
B(k,:)=circshift(A,[1 k-1]);
end
B
