Area of simple curve bounded by
The discussion revolves around finding the area under the curve defined by the equation 2/sqrt(x), bounded by the lines x = 0, y = 3, and y = 1. Participants are exploring different methods of integration to determine the area accurately.
  • Mixed
  • Participants discuss using both vertical and horizontal elements for integration, noting discrepancies in their results. One participant attempts to set up integrals based on vertical elements, while another explores the use of horizontal elements, leading to different outcomes. Questions arise regarding the correctness of the textbook's claimed answer and the setup of the integrals.
The discussion is ongoing, with participants sharing their attempts and questioning the validity of the textbook's answer. Some guidance has been provided regarding the need for multiple integrals based on the chosen method of integration. There is no explicit consensus on the correct area yet, but participants are actively engaging with the problem.
Participants are working under the constraints of the problem as stated, and there is a noted discrepancy between their calculated areas and the answer provided in the textbook. The discussion includes considerations of boundaries and the implications of using different integration methods.
Dumbledore
Find the area of the curve 2/sqrt(x) bounded by x = 0, y = 3, y = 1
The textbook claims the answer is 3.
I tried both vertical and horizontal elements, but got different answers than 3.
Here's my attempt at vertical elements:
since y = 1 is the farthest right value of x, I solve 1 = 2/sqrt(x) for X to find x upper, which is 4.
Now I form my integral: integral(4-0) of 2/sqrt(x) (dx)
Integrate: 4 * sqrt(x)
Solve the definite integral: (4 * sqrt(4)) - (4 * sqrt(0)) = 8
What have I done wrong?
When y= 3, x= 4/9. But your left boundary is x= 0 so you have the lines y= 1 and y= 3 as upper and lower bounds until x= 4/9. The area is
[tex]\int_0^{4/9} (3-1)dx+ \int_{4/9}^4 2/\sqrt{x}dx[/tex]
What did you get when you integrated with respect to y?
Thanks I finally understand why I have to use two integrals to figure out this question if I use vertical elements.
For horizontal elements, I did this:
Integral(3-1): (4/y^2) (dy)
Integrate: -4 * y^(-1)
Solve: -4*(1/3) - (-4)(1)
Equals: 2 and 2/3
What did I do wrong this time?
Nothing. Unless you have stated the problem incorrectly, that is the correct answer.
My textbook is incorrect as I suspected. It claims the answer is 3.
Thanks for your help.
  • · Replies 105 ·
13K
