Box Mechanics: Solving for Speed, Energy, Force, and Work
The problem involves a 100 kg box being pulled along a rough surface, with its position described by a cubic function of time. Participants are tasked with determining the speed, kinetic energy, net force, power, and work done on the box over a specified time interval.
  • Mixed
  • Participants discuss the calculation of velocity and kinetic energy, with some uncertainty about the correct formulas to use. Questions arise regarding the application of the kinetic energy formula and the relationship between force, velocity, and power.
Some participants have provided partial calculations and confirmations of each other's work, while others express uncertainty about specific steps and concepts. There is an ongoing exploration of different methods to calculate power and work, with no explicit consensus reached yet.
Participants are navigating through multiple interpretations of the problem and are encouraged to clarify their assumptions and reasoning. The discussion reflects a collaborative effort to understand the underlying physics concepts without providing direct solutions.
dbb2112
A 100 kg box is being pulled along the x-axis by a student. The box slides along the a rough surface and its position x varies accoring to the equation x=.5tcubed +2t, where x is in meters and t is in seconds.
a. Determine the speed of the box at t=0
b. Determine the following as functions of time t.
i. The kinetic energy of the box
ii. the net force acting on the box
iii. The power being delivered to the box.
c. Calculate the net workdone on the box in interval t=0 t t=2
d. Indicate below wheter the work done on the box by the student in the interval t=0 to t=2 wold e greater than, less than or eequal to the answer in part c.
honestly, I have no idea.
ok what i have so far is that the velocity = 1.5t^2+2, which means the speed at 0= 2.
Then when it asks for the kinetic energy I am not sure if it would be 1/2(100)(2^2) or 1/2 (100)(1.5t^2+2).
anyone
Hi dbb2112,
Your answer for part a looks right to me.
For part b, neither one is quite right. The first form 1/2(100)(2^2) is the kinetic energy at t=0.
The second one:
1/2 (100)(1.5t^2+2)
is closer, but you need to square the speed. What do you get for the other answers?
O you i just forgot to put the squared. But for the net force F=ma so i would get 100(3t) or 300t for the net force?
That looks right to me.
Um about the kinetic energy again whenever i have 1/2(100)(1.5t^2+2)^2 would i have to square the 1.5 t part or could i leave it as 50(1.5t^2+2)^2
I believe this last expression is right (I'm not sure what you mean by square the 1.5 t part).
nevermind. About the power being delivered I am not really sure what to do here.
What two ways of calculating power are there; what are their formulas and which one applies to this case?
Power=work/time?
dbb2112 said:
Power=work/time?
No, that is the average power (over an interval). What's the other?
power= force*velocity
That's right.
How would you find the net work done from t=0 to t=2?
honestly, i am not sure.
What is the work equal to? In other words, why is it impotant? For example, if I tell you that 10J of work is done on an object, what do you know about that object?
How about the change in Kinetic energy is equal to the net work
I know i but when you got offline i wanted someone else and therefore posted a new one.
That's correct about the net work.
However, duplicate threads are not allowed on this forum. Please stay with the original thread for this problem.
o ok thanks though
