Einzel Lens Operating Principle
  • Context: Graduate
  • Thread starter Thread starter craq
    Lens Principle
The discussion revolves around the operating principle of an Einzel lens used for focusing ion beams. Participants explore the behavior of ion trajectories in relation to electric potential distributions, simulation techniques, and software development for modeling particle motion. The scope includes theoretical considerations, technical explanations, and practical applications in ion beam design.
  • Experimental/applied
  • One participant notes that literature indicates the ion beam diverges in the first gap and converges in the second gap, questioning why positive ions would be attracted to a region of higher potential.
  • Another participant shares that they resolved their initial confusion by allowing their Laplace solver to run longer, leading to a more accurate voltage profile.
  • A participant mentions developing their own software for determining trajectories of electrons and ions in various lenses, expressing interest in the original poster's development.
  • Commercial software options are suggested for simulating ion trajectories, with a specific reference to Simion.
  • One participant describes their approach to solving the Laplace equation and applying the Lorentz equation for particle motion, while noting the omission of space charge effects.
  • Another participant inquires about the application of the software, revealing their own project involves a homemade Time of Flight Mass Spectrometer and discussing their method of applying Snell-Descartes law in their software.
  • A participant explains their goal of achieving real-time control of the ion beam diameter and discusses the challenges of visualizing particle trajectories and the need for numerous test particles to understand dependencies on radial position and initial velocity.
Participants express varying approaches and methods for simulating ion trajectories, with no consensus on the best technique or the effectiveness of the Einzel lens for their specific applications. The discussion remains unresolved regarding the optimal modeling strategies and the implications of their findings.
Participants mention limitations in their simulations, such as the initial conditions affecting voltage profiles and the potential impact of space charge effects at low velocities, which remain unresolved.
Readers interested in ion beam technology, simulation software development, and the theoretical underpinnings of particle motion in electric fields may find this discussion relevant.
craq
I'm trying to design an Einzel lens to focus an ion beam. The literature seems pretty consistent that the beam diverges in the first gap and converges in the second gap. (Gaps are between the three electrodes.) What I don't understand is that the potential is lowest at the centre of a cylindrical lens (highest closer to the central electrode). Why should the positive ions be attracted to a region of higher potential?
I have written a simulation which solves for voltage (the laplace equation by the finite difference method), finds the electric field (as the gradient of voltage) and then calculates the particle trajectory. The simulation results show the beam bending towards the axis at the first gap and hardly any change at the second one.
I'm obviously missing something here, can anyone point it out to me?
Science news on Phys.org
Ok, I figured it out... just needed to let the laplace solver run to a few (thousand) more iterations to get a better solution for the voltage profile. My initial conditions are V=0 and the centre of the cylinder stayed pretty close to 0, giving a radially inwards electric field everywhere. (Except very close to the axis, where it was very slightly outward, small enough that I dismissed it as a numerical error.)
Hello. I've myself developped a software in order to determine trajectories of electrons and ions in every kind of lenses, so I'm interested by your own developpement ...
If you (or your company, or your thesis professor) can afford it, there is commercially available software that does this:
http://www.simion.com/
Hi,
this was just for a one-off design, so I had a look at the Simion demo but decided to write it myself in Matlab. Oversimplifying for a second, its just solving the Laplace equation to give the potential distribution and then the Lorentz equation for the motion of the particles (later in the trajectory I have a confining magnetic field too). I ignore space charge effects, although I have been warned that at low velocities they can be dangerous.
I used a multi-grid Gauss seidel method to accelerate the convergence of the finite difference equation. These guys explain it really well:
grids.ucs.indiana.edu/ptliupages/jsucourse2005/jsuparallelpdesolution05.ppt
There were a couple of other problems I ran into, but nothing really tricky... And eventually I was able to show that an Einzel lens is unfortunately not going to work for us.
If you have any suggestions, or want to know anything specifically about my simulation I'd be glad to hear from you.
Could you tell what application is yours. Mine is an homemade Time of flight Mass spectrometer. To return to your software development, after having solved Laplace equation, you directly use forces (Field) lines, in my software I apply Snell-Descartes law between 2 successive equipotential lines ...
I am building an ion beam, and the lens was intended to give real-time control of the beam diameter.
Snell-Descartes is an interesting idea, possibly it solves much faster, but I can't immediately see how to code it. My goal was to visualise particle trajectories, so I find the acceleration at each location and solve kinematic equations to give the velocity and position. The drawback here was that to get a good indication of the dependence on radial position and initial velocity meant I had to take a large number of test particles.
  • Poll Poll
