Lagrange Multipliers, calc max volume of box
The discussion focuses on using the Method of Lagrange Multipliers to maximize the volume of a rectangular parallelepiped inscribed within the ellipsoid defined by the equation 2x² + 10y² + 5z² = 80. The function to maximize is f(x,y,z) = xyz, with the constraint g(x,y,z) = 2x² + 10y² + 5z² - 80 = 0. The solution involves deriving equations from the gradients and substituting to find the maximum volume, ultimately leading to the coordinates of point P as x = √5y, z = √2y, and y = √(8/3).
  • Understanding of Lagrange Multipliers
  • Familiarity with ellipsoid equations
  • Knowledge of partial derivatives
  • Basic algebra for solving equations
  • Study the application of Lagrange Multipliers in optimization problems
  • Learn about the properties of ellipsoids and their equations
  • Explore advanced techniques in multivariable calculus
  • Practice solving similar optimization problems with constraints
Students in calculus, mathematicians focusing on optimization, and anyone interested in applying Lagrange Multipliers to real-world problems.
hils0005
Point P(x,y,z) lies on the part of the ellipsoid 2x^2 + 10y^2 + 5z^2 = 80 that is in the first octant of space. It is also a vertex of a rectangular parallelpiped each of whose sides are parallel to a coordinate plane. Use Method of LaGrange Multipliers to determine the coordinates of P so that the box has a max volume and calculate the max
f(x,y,z)=xyz g(x,y,z)=2x^2+10y^2+5z^2=80
[tex]\nabla[/tex]f=[tex]\nabla[/tex]g[tex]\lambda[/tex]
1.yz=4x[tex]\lambda[/tex]
2.xz=20y[tex]\lambda[/tex]
3.xy=10z[tex]\lambda[/tex]
I multiplied equation 1 by x, 2 by y and 3 by z
4x^2[tex]\lambda[/tex]=20y^2[tex]\lambda[/tex]=10z^2[tex]\lambda[/tex]
I then put x and z in terms of y and put into constraint
4x^2=20y^2 10z^2=20y^2
x=[tex]\sqrt{}[/tex]5 y z=[tex]\sqrt{}[/tex]2 y
g=2([tex]\sqrt{}[/tex]5y)^2 +10y^2 + 5([tex]\sqrt{}[/tex]2y)^2=80
solving for y=[tex]\sqrt{}[/tex](8/3)
I'm not sure if I'm on the right track or if this is way off, if correct do I just do the same proceedure to find x and z?
You are doing fine. You don't need to repeat the procedure for x and z. You already have x=sqrt(5)*y and z=sqrt(2)*y. Once you've got y, you've got everything.
  • · Replies 16 ·
