Line Integral of F(x,y,z) over Unit Circle
The discussion revolves around calculating the line integral of a vector field F(x,y,z) over a unit circle parameterized in two dimensions. Participants are exploring the implications of working with a three-dimensional vector field while integrating over a two-dimensional path.
  • Participants discuss the challenge of matching dimensions between the vector field and the path, questioning how to handle the z-component when integrating over a 2D circle. There are attempts to clarify the implications of assuming z=0 and the necessity of defining z in the context of the problem.
The discussion is ongoing, with participants providing insights into the dimensionality issue. Some guidance has been offered regarding the need for a z-value to properly define the path in three dimensions, but no consensus has been reached on how to proceed with the integral.
There is a noted lack of specification regarding the z-component in the original problem statement, leading to confusion among participants about how to interpret the vector field in relation to the unit circle.
stanford1463
What is the line integral of F(x,y,z) = (xy, x, xyz) over the unit circle c(t) = (cost, sint) t E (0,2pi) ?
integral= (f(c(t))*c'(t))dt)
Ok, so I tried solving this like I would any other line integral using the given equation, but it does not work, since I am taking a 3D function on a 2D function (circle) ? So...f(c(t)) cannot be anything?? As cos t can be x, sint can be y, but what is z?? I know you take the dot product, and solve, taking the integral, but I cannot figure out how to find f(c(t)) as one function has 3 variables and the other has 2? Thanks!
z is zero. The circle is (cos(t),sin(t),0). The dimensions have to match or you can't take a dot product. If one is three dimensional the other must be as well, even if they don't spell it out.
Ok thanks! But what if it's something like F(x,y,z)=(xy, x/z, y/z) ? Then if you plug in 0, you get a denominator of zero...
Didn't you read Dick's response? The problem is that "c(t)= (cos(t), sin(t))" is two dimensional and you CAN'T integerate a 3 dimensional vector function over a two dimensional path. Are you interpreting that to mean that it must be (cos(t), sin(t), 0)? There is no reason to assume that because z is not mentioned, it must be 0. You MUST have some equation involving z, perhaps "z= 0", perhaps "z= 1", in order that the path be defined in three dimensions.
I guess I automatically think of THE Unit Circle, as lying in the x-y plane. But Halls is right, they should have specified a z value.
