How to Calculate Kinetic Energy Relative to Center of Mass?
  • Thread starter Thread starter lebprince
    Particles System
This discussion focuses on calculating the kinetic energy of a system of three particles relative to the center of mass (COM). The particles have masses m1 = 4 kg, m2 = 6 kg, and m3 = 3 kg, with respective velocities of <10, -4, 15> m/s, <-14, 6, -4> m/s, and <-21, 39, 19> m/s. The user successfully solved for total momentum, velocity of the COM, and translational kinetic energy but sought assistance specifically for calculating the kinetic energy relative to the COM. The solution involves determining the relative velocities of each mass to the COM and then calculating the kinetic energy from these relative velocities.
  • Understanding of vector addition and subtraction
  • Knowledge of kinetic energy formula: KE = 0.5 * m * v^2
  • Familiarity with the concept of center of mass
  • Basic principles of momentum conservation
  • Calculate the center of mass for a system of particles
  • Learn how to derive relative velocities in multi-particle systems
  • Study the derivation of kinetic energy formulas in relation to the center of mass
  • Explore examples of momentum conservation in particle systems
Students studying physics, particularly those focusing on mechanics and kinetic energy calculations, as well as educators looking for practical examples of center of mass applications.
lebprince
Consider a system consisting of three particles:
m1 = 4 kg, 1 = < 10, -4, 15 > m/s
m2 = 6 kg, 2 = < -14, 6, -4 > m/s
m3 = 3 kg, 3 = < -21, 39, 19 > m/s
(a) What is the total momentum of this system?
(b) What is the velocity of the center of mass of this system?
(c) What is the translational kinetic energy of this system?
(d) What is the kinetic energy of this system relative to the center of mass?
(e) What is the total kinetic energy of this system?
i was able to solve parts a , b, c and i know that part e is the addition of part c + part d , i need help on part d. Thanks
Hi lebprince! :smile:
Velocities are vectors, so they obey vector addition (and subtraction!).
If the velocities of the masses and the c.o.m. are A B C and V,
then find the vectors VA VB and VC …
that gives you velocities of the masses relative to to the c.o.m. …
from which you can get the KE relative to to the c.o.m. :smile:
  • · Replies 25 ·
  • · Replies 21 ·
