What is the scale reading when the block starts to slide down the incline?
The problem involves a block resting on an inclined wedge, with the wedge placed on a scale. The scenario describes the transition from static friction to a situation where the block begins to slide down the incline, prompting a change in the scale reading.
  • Participants discuss the forces acting on the block and wedge, particularly the role of the normal force and its vertical component. Questions arise regarding the mechanics of the system when the block is at rest versus when it begins to slide.
Some participants have provided insights into the forces involved, particularly the normal force's contribution to the scale reading. There is ongoing exploration of the differences in force dynamics between the static and sliding scenarios, with no explicit consensus reached on the underlying mechanics.
The discussion includes assumptions about friction and equilibrium conditions, as well as the impact of the block's motion on the scale reading. The original poster expresses uncertainty about the forces at play when the block starts to slide.
mjolnir80
say we have a block resting on a incline of a wedge (the incline is 40 degrees). the wedge is on a scale(mass of block is .2 kg and mass of wedge is .8kg).if the block is at rest (due to to static friction) the scale would read 9.8N. but let's say we eliminate the friction on the wedge and the block starts to slide down the incline. the friction between the wedge and the scale is large enough to keep the wedge still on the scale.what would the scale read now?
i somehow accidentally got the right answer to this (which is 8.99N) but i still don't wuite understand what happens when the block starts to slide. i know that the block would start pushing against the wedge as it goes down but i don't see which force is doing the pushing?
can someone help me out with this
It's the vertical component of the normal force between the block and the wedge that does the pushing. The scale reads the vertical normal force acting on it. you need to draw a free body diagram of the top block to look at what the normal force is between the block and wedge, then look at the vertical component of that force.
thanks for the help
one more thing how come the vertical component of the normal force doesn't affect the wedge when the blaock is standing still?
mjolnir80 said:
thanks for the help
Sure it does. The scale records a weight of 9.8N, which is the sum of the weights of both the wedge and block. There must be friction force on the block when it's still, and that vertical component of friction contributes also, along with the normal force vertical contribution, to the scale reading. But also in that at rest situation, you needn't consider the block's normal or friction force directly; just look at the system itself, it is in equilibruium, so the scale force must read the total weight of the block and wedge. In the other case where the block is sliding down the plane, the scale reading is less because the top block is not in equilibrium in the vertical direction.
10K
