A question regarding the number of fermions with a certain velocity component
The discussion focuses on deriving the number of electrons with a specific x-component of velocity, represented by the equation dN = (4πV m² k_B T / h³) ln [exp((E_F - mv_x²/2) / k_B T) + 1] dv_x. The Fermi-Dirac distribution function is utilized, where dn/dE = (4πV √(2m³) / h³) (√E / (exp((E - E_F) / k_B T) + 1)). The participant seeks assistance in integrating over the velocity components vy and vz, using the relationship t² = vy² + vz² to facilitate the calculation.
  • Understanding of Fermi-Dirac statistics
  • Familiarity with kinetic energy equations
  • Knowledge of integration techniques in physics
  • Proficiency in manipulating mathematical expressions involving logarithms and exponentials
  • Study the derivation of the Fermi-Dirac distribution function
  • Learn about kinetic energy transformations in statistical mechanics
  • Explore integration techniques for multi-variable functions
  • Investigate the physical significance of the Fermi energy (E_F) in electron distributions
Students and researchers in physics, particularly those focusing on statistical mechanics, quantum mechanics, and solid-state physics, will benefit from this discussion.
Jopi
Prove that the number of electrons whose velocity's x-component is between [x,x+dx] is given by
[tex] dN = \frac{4\pi V m^2 k_B T}{h^3} ln [exp(\frac{E_F -mv_x^2/2}{k_B T})+1]dv_x[/tex]
The Fermi-Dirac Distribution function:
[tex] \frac{dn}{dE}=\frac{4\pi V \sqrt{2m^3}}{h^3}\frac{\sqrt{E}}{exp \left((E-E_F)/ k_B T\right) +1}[/tex]
Where E is kinetic energy,
[tex] E=\frac{1}{2} m v^2.[/tex]
First, I used the definition of kinetic energy above to rewrite the distribution as a function of velocity. I got
[tex] dn=\frac{V m^{3/2}}{h^3}\frac{1}{exp((\frac{1}{2} m v^2 -E_F)/k_B T) +1} 4 \pi v^2 dv[/tex]
Now, we know that
[tex] 4 \pi v^2 dv = dv_x dv_y dv_z.[/tex]
Now I should be able to get the number of particles with vx in the given range by integratin out dvy and dvz. In the assignment it is suggested that I write
[tex] t^2=v_y^2+v_z^2[/tex]
and then I can use the formula
[tex] \int_0^{\infty} (ae^x+1)^{-1}dx=ln(1+\frac{1}{a}).[/tex]
But I don't know how to do that. What is the differential element dvydvz written with dt?
Think of vy and vz as cartesian coordinates, and t as the radial coordinate in the plane.
You should then be able to derive/remember the 2-D analog of the equation you have already written down:
  • · Replies 0 ·
