Is Work Path Dependent with a Zero Total Displacement?
  • Thread starter Thread starter fiziksfun
    Path Work
Work is path dependent, contrary to the initial assumption that it is a state function like energy. In scenarios where an object returns to its original position, such as dragging a block across a rough surface and back, work is still performed due to the force exerted against friction. Therefore, even with zero total displacement, work is done when a force acts on a moving object. This highlights the importance of considering the path taken when evaluating work done in physics.
  • Understanding of basic physics concepts, specifically work and energy.
  • Familiarity with the definition of displacement in physics.
  • Knowledge of forces and friction in mechanical systems.
  • Basic grasp of state functions in thermodynamics.
  • Research the mathematical definition of work in physics, including the formula W = F · d · cos(θ).
  • Explore the concept of path independence in conservative forces.
  • Study examples of work done against friction in real-world applications.
  • Learn about energy conservation principles related to work and displacement.
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of work and energy in physical systems.
fiziksfun
Is work done if the total displacement is 0?
It doesn't matter what path the object took to get from A back to A, right? As long as it ends at A, then its zero work, correct?
So work IS NOT path dependent, it's a state function, like energy, right ?
In general, yes.
No. In general even if the displacement is zero when a force acts on a moving object, work is done.
Nope, work is path dependent.
For example, consider dragging a block across a rough surface for a distance of ten meters and then dragging it back to the same place you started. Did you do work on that block?
  • · Replies 23 ·
  • · Replies 28 ·
