What is the mass of the aluminium chunk?
The discussion focuses on calculating the mass of an aluminum chunk when placed in thermal equilibrium with water and a copper cube. The specific heat capacities are defined as 899 J/kg°C for aluminum and 387 J/kg°C for copper. The problem states that the water (325 g at 28°C) and aluminum gain heat while the copper (472 g at 87°C) loses heat, resulting in a final temperature of 28°C. The solution involves applying the principle of conservation of energy, leading to the equation: water + aluminum = copper.
  • Understanding of specific heat capacity and its formula: mc(Tf-Ti)
  • Knowledge of thermal equilibrium and the first law of thermodynamics
  • Familiarity with unit conversions (grams to kilograms)
  • Basic algebra for solving equations
  • Calculate the mass of the aluminum chunk using the equation derived from thermal equilibrium.
  • Explore the concept of latent heat and its application in phase changes.
  • Learn about specific heat capacities of various materials for comparative analysis.
  • Investigate real-world applications of thermal energy transfer in engineering.
Students studying thermodynamics, physics enthusiasts, and educators looking for practical examples of heat transfer and specific heat calculations.
mustang
Problem 7.
Given; specific heat of water=4186 J/kg* degrees celsius
Brass is an alloy made from copper and zinc. A 0.66 kg brasss sample at 98.6 degrees Celciusus is dropped into 2.33 kg of water at 4.6 degrees celsius. If the equilibrium temperature is 7.0 degrees Celciusus, what is the specific heat capacity of brass? In J/kg*Celciusis.
Problem 9.
A student drops metallic objects into a
224 g steel container holding 325 g of water
at 28±C. One object is a 472 g cube of copper
that is initially at 87 degrees C, and the other is a
chunk of aluminum that is initially at 9 degreesC.
To the students's surprise, the water reaches
a final temperature of 28 degreesC, precisely where
it started.
What is the mass of the aluminum chunk?
Assume the specifc heat of copper and alu-
minum are 387 J/kg degrees C
± C and 899 J/kg degrees C
Problem 12.
Given: specific heat of water = 4186 J/kg degrees Ceicuis
and water's latent heat of fusion = 3.33 *10^5 J/kg.
A 0.012 kg cube of ice at 0.0degrees Ceicuis is added to
0.459 kg of soup at 80.4degrees Ceicuis.
Assuming that the soup has the same specific
heat capacity as water, find the final tem-
perature of the soup after the ice has melted.
Answer in units of degrees Ceicuis.
Rightyo. A handy thing to do for specific heat problems is to imagine "what is loosing heat" and "what is gaining heat"
So for Problem 7, the water gains heat and the brass looses heat
And, given that no energy is lost externaly (a simplicication we use for such problems) all the energy lost by the brass must equal the energy gained by the water.
the energy lost or gained is given by mc(Tf-Ti)
where
m is the mass of a substance,
c is the specific heat capacity of a substance,
Tf is the final temperature of the substance
Ti is the initial temperature of the substance
we use this for both the brass and water
Now, first law of Thermodynamics states that two objects will gain or loose heat to be in thermal equilibrium with each other. So Tf for both the water and the brass will be the same.
Brass = Water
mc(Tf-Ti) = mc(Tf-Ti)
.66 * c * (7-98.6) = 2.33 * 4186 * (7-4.6)
Now the only thing you need to know is c (specifiv heat of brass). So solve for c.
For Problem 9, the water and aluminum gain heat and the copper looses heat. The steel container is mentioned but no specific heat is given for it so i assume you are not to use it. If you are you have to take note that it also gains heat (and is at the same temp as the water due to thermal equilibrium)
so use water + aluminium = copper
For Problem 12, the soup looses heat and the ice gains heat going from 0 to equilibrium and also from changing state from solid to liquid.( this takes up l*m jouls where m is the mass of ice and l is the latent heat of fusion.)
Regards to problem 9
Could you go more in dept with problem 9.
Water+ aluminium = copper
Water : m=325g
28 degrees Celciusus
aluminium: m=?
specifc heat: 899 J/kg degrees C
copper: m=472g; temp=87 degrees C
specifc heat: 387 J/kg degrees C
10K
10K
