Solving 5th Degree Characteristic Eq. of Linear Homog. Diff. Eq.
The discussion revolves around solving the characteristic equation of a fifth-degree linear homogeneous differential equation. Participants explore methods for finding roots of higher-order polynomial equations and the challenges associated with them.
  • Participants discuss the application of the rational root theorem and the challenges of solving fifth-degree polynomials. There are inquiries about efficient methods for finding roots of characteristic equations, especially for higher-order differential equations.
The conversation includes various approaches to finding roots, with some participants suggesting numerical methods as alternatives when exact solutions are difficult. There is no explicit consensus on a single method, and multiple interpretations of the problem are being explored.
Participants note the complexity of solving higher-order characteristic equations and the limitations of existing methods, such as factoring and the rational root theorem. The original poster expresses a desire for quicker solutions, indicating a potential constraint in time or efficiency.
bobmerhebi
Given an nth order linear homog. diff eq.
how can I find the solution for its nth degree characteristic eq?
I know its simple Algebra but please help. if possible please give a 5th deg eq. thx
The characteristic equation is a 5th degree polynomial equation. As the link Vid provided says, there is NO general formula for solving fifth or higher degree polymnomial equations. You can try, for example, the "rational root theorem" which says that if m/n is a rational number satifying [itex]a_nx^n+ a_{n-1}x^{n-1}+ \cdot\cdot\cdot+ a_0=[/itex], with all coefficients integer then m must evenly divide [itex]a_n[/itex] and n must evenly divide [itex]a_0[/itex]. IF there is a rational root, that at least reduce the possiblilities.
the thing is if I am given an ordinary linear homog. differe eq of order greater than 2. how should i solve it?
how could i get the roots of the eq. LaTeX Code: a_nx^n+ a_{n-1}x^{n-1}+ \\cdot\\cdot\\cdot+ a_0= 0
in order to find the general sol. of the D.E.
forexample: 4y''' - 3y' + y = 0. this eq. gives 4m3 - 3m + = 0 as a characteristic eq.. how can this low deg. eq be solved? & how can it be applied to higher degree ones. (in other words i need a fast & easy way to find the roots to use in sovlving D.E.'s).
I get that the roots of the above eq. are -1 & 1/2; where 1/2 is a repeated root.
i got the roots by looking @ the divisors of the 1st & last coefficients & dividing the divisors of the last coefficient by the divisors of the 1st one (like +or - 1/4, +/- 1/2, ...) & them checking which makes the polynomial zero. then simplifying the polynomial by dividing it by (x - root found) & finding a low deg polynomial.
but this way takes time, specially if i have a higher order D.E.
so what do u have to say?
Do what you did. Factor them. If you can't factor them, you are in big trouble as far as solving them exactly. You can always solve them numerically. I'm sorry if it takes time. But that's life.
9K
