ando
If Two objects, both traveling in a vacuum, go from point A to B, but one object travels twice as fast - does that take more, less or the same amount of energy?
The discussion centers around the energy consumption of objects moving in a vacuum, specifically comparing the energy required for two objects traveling from point A to B at different speeds. Participants explore concepts related to kinetic energy, force, and the implications of motion in a vacuum, as well as a tangential question about energy expenditure in walking versus running on Earth.
Participants express differing views on the relationship between speed, kinetic energy, and energy expenditure in a vacuum. There is no consensus on whether moving faster requires more energy, as some assert it does not while others argue it does. The discussion about walking versus running also reveals conflicting opinions, indicating that the topic remains unresolved.
Participants highlight that the initial conditions of motion (e.g., starting velocity) and the absence of external forces are critical to understanding energy consumption in a vacuum. The discussion also touches on the complexities of energy expenditure in biological systems, which may not directly correlate with physical principles discussed in the vacuum scenario.
You don't apply energy to things. You apply forces.Originally posted by MrCaN
The speed at which a object moves is dependent on the energy applied to it.
The statement "both traveling in a vacuum" implies that both objects have a nonzero starting velocity at point A. Therefore it requires no energy for either to get to point B, assuming that point B is along a direct line from point A coincidental to both trajectories. See Newton's 1st law - inertia: particle in motion will remain in motion unless there is a force acting upon it.ando asked:
Basically I don't know what I'm talking about and I really didn't know what I was asking. I really just wanted to know if walking a mile on planet Earth burns more, less, or the same amount of energy as running a mile.
My friend says that if you take a step, it doesn't matter wether you do it fast or slowly, it burns the same amount of energy.]
