Impact Force after falling of a chair
The discussion focuses on calculating the impact force experienced by a person weighing 100 kg when falling backward from a chair with a height of 1100 mm. The complexity arises from the need to account for the pendulum effect due to the chair's dimensions and the deceleration experienced upon impact with a hard floor. Key factors include the deceleration rate of the head upon striking the floor, which is influenced by the skull and brain's differing responses to impact forces. The conversation emphasizes the importance of understanding these dynamics for accurate force calculations.
  • Understanding of basic physics principles, particularly Newton's second law (F=ma).
  • Knowledge of biomechanics, specifically how different body structures absorb impact forces.
  • Familiarity with pendulum motion and its effects on falling objects.
  • Experience with impact force calculations in real-world scenarios.
  • Research the biomechanics of head injuries and impact forces.
  • Learn about pendulum dynamics and its application in fall scenarios.
  • Explore advanced physics simulations for impact force calculations.
  • Investigate safety standards for chair design and fall prevention measures.
Engineers, safety professionals, healthcare providers, and anyone involved in accident analysis or injury prevention related to falls.
Steve Smith
Hi,
Hopefully somewone will know the calculation to find out the impact force for one person sitting on a chair and falling backwards with a full deaceleraton to a hard floor, what would the impact force be to the base of he head when stricking the floor.
Chair is a chair with a bottom and a back rest section
From floor to bottom of chair 360 mm
Whilst in the sitting position head from floor 1100 mm
Weight of person on the chair 100 kg
The chair flips backwards and the person goes backwards sitting on the chair and head strikes the floor, what would the impact force to the persons back of the head be ?
Regards,
Steve Smith
This is very hard to calculate, you can get the speed they hit the floor with fairly easily.
But the force will depend on how their head slows down as it hits (f=ma where 'a' is the deceleration)
It's even more complicated for a head, the skull will slow at a certain rate but the brain will slow down at a different rate as different structures absorb energy in different ways.
Hi,
I agree with your statement to mesure the aceleration one problem I believe in the calculation is that the movement of the fall is dot directly downward but a slight pendulum affect as tha chair tilts over the head is not making a direct fall from 1100 mm but swinging at a pendulum that is why i mention the chairs dimensions.
The deacelaretion would be 0 mm hitting a concreted or tiled floor as no movement could still occur after the impact.
Yes the brain momentum and force would be diffrent due to t own density / mass / weight and the liquid between the brain and scull.
Just wanting the calculation based on the imact force to the floor but not as a 100% downward fall but a pendulum fall due to the chair dimensions.
Many thanks for your reply.
Regards
Steve Smith
  • · Replies 16 ·
14K
